Corel Dazzle DVD Recorder HD
Quicklinx: C76JWS00 Mfr#: DVCPTENAM
Featuring a high-quality video capture device plus powerful Pinnacle Studio HD editing, Dazzle DVD Recorder HD makes it easy to create movies like a pro. Quickly import videos and photos, then edit scenes and add professional polish with an extensive library of effects, transitions, and soundtrack options.
Share your masterpiece directly on the web with one-click uploading to YouTube, or easily transfer your video to an Apple iPod, Sony PSP, or other device. Thanks to Dazzle DVD Recorder HD, it's never been easier to create and share amazing HD videos.
Dazzle DVD Recorder HD - video capture adapter - USB 2.0
Video capture adapter
Interface Type
USB 2.0
Video Input
S-video input, composite video input
Analogue video Signal
S-Video, composite video
Digital Video Format
MPEG-1, MPEG-2, MPEG-4, QuickTime, AVI, DV, RealVideo 8, DivX, WMV, AVCHD, HDV, 3GPP
Audio Input Support
Standard
Microsoft Windows 7, Microsoft Windows Vista SP2, Microsoft Windows XP SP3
Interface Type
USB 2.0
Video
Interface Type
Audio Input Support
Standard
1 x display / video - S-video input - 4 pin mini-DIN , 1 x display / video - composite video input - RCA , 1 x audio - input - RCA x 2
1 x USB 2.0 - 4 pin USB Type A
Software Included
Pinnacle Studio HD 14
System Requirements Details
Pentium - 1.8 GHz - RAM 1 GB - HD 3.2 GB
