Corel CorelDRAW Graphics Suite X8
Quicklinx: C75WWS00 Mfr#: CDGSX8IEDP
Type: Creativity - graphics & image editing
Compatibility: PC
Media: DVD-ROM
  • Windows 8.1 (32/64 bits)
£385.06 ex VAT
£462.07 inc VAT
Combine your creativity with the unparalleled power of CorelDRAW Graphics Suite X8 to design graphics and layouts, edit photos, and create websites. With multi-monitor viewing and 4K displays, the suite lets first-time users, graphics pros, small business owners and design enthusiasts deliver professional results with speed and confidence. Discover high-caliber and intuitive tools to create logos, brochures, web graphics, social media ads or any original project. CorelDRAW your way.
  • Multi-monitor, 4K and Real-Time Stylus support
    Take advantage of the multi-monitor viewing and 4K displays support. Work quickly and efficiently with the added control from the Windows Real-Time Stylus pen-compatible tablets, such as the Microsoft Surface, in addition to the Wacom tablet and devices.
  • Corel Font Manager
    Explore, handle and organize fonts with the Corel Font Manager to satisfy all your typeface needs. Manage your typeface and font collections with ease, and use fonts without having to install them. We've got you covered for every profession that uses fonts daily, from graphic design, publishing and illustration, to package design, sign making, advertising and website design.
  • Font filtering and search
    Save valuable design time with the enhanced font filtering feature. Quickly find the specific font you need without spending time searching in multiple folders. For example, if you're looking for a typeface that has a handwritten appearance, you can do a quick search for "script fonts". The font list will automatically update to show all the fonts on your machine that match that search.
  • Show objects
    Take advantage of the important design features that created based on feedback from CorelDRAW users. Manage complex projects with ease by using the Hide and Show Objects feature that lets you hide individual objects or groups of objects on a layer without hiding the entire layer.
  • Copy curve segments
    Copy, paste, or duplicate pieces of existing curves with the Copy Curve Segments feature that allows you to reuse curve segments in your projects.
  • Gaussian blur feature
    Explore the Gaussian Blur lens, featured within Corel PHOTO-PAINT, for non-destructive blur effects. Adjust the degree to which the drop shadow feathers at its edges in CorelDRAW so you can control the perceived distance and size of objects against the background and other elements.
  • Healing Clone tool
    Improve your favorite photos with powerful tools to correct and edit in a variety of ways. Try the new Healing Clone tool to remove imperfections by blending them with surrounding colors and textures. Explore the many professional photo-editing tools within Corel PHOTO-PAINT.
  • Straighten Image dialog box
    With the enhanced Straighten Image dialog box in CorelDRAW and Corel PHOTO-PAINT, you can now correct perspective distortions in photos that have straight lines and flat surfaces such as architectural photos and photos of buildings.
  • Knife tool
    With the revamped Knife tool in CorelDRAW, split any object or group of objects - vector, text and bitmaps - along straight, freehand or Bézier lines. Create a gap between the new objects resulting from the splitting action or overlap them.
  • Workspace customization
    Be productive immediately with a workspace that matches your workflow needs. Simply adapt your design space by changing the appearance of your commonly used elements: alter the desktop and window borders color, customize the icons and text size. Work your way!
CorelDRAW Graphics Suite X8 - box pack - 1 user
Box pack
Category
Creativity application - graphics & image editing
Licence Qty
1 user
Platform
Windows
Language
English
Distribution Media
DVD-ROM
Category
Box pack
Platform
Windows
Distribution Media
DVD-ROM
Language
English
Licencing
Licence Type
1 user
Supported OS
Microsoft Windows 7 (32/64 bits) SP1 or later, Windows 8.1 (32/64 bits), Windows 10 (32/64 bits)
Hardware Requirements
Microsoft Windows - RAM 2 GB - HD 1 GB
Additional Requirements
Mouse or compatible device, DVD-ROM, Internet connection, 1280 x 720 monitor resolution, Internet Explorer 11 or later, Microsoft .NET Framework 4.6
Compatibility: PC
Media: DVD-ROM
Brand: Corel
Price Range Ex VAT: 300 - 500
