CoolerMaster VS Series V 750W 80 Plus Gold Modular Power Supply Unit
Quicklinx: B5HFWS00 Mfr#: RS750-AMAAG1-UK
Cooler Master VS series power units are 80 PLUS Gold certified, designed for PC gamers and performance enthusiasts. Thanks to Cooler Master exclusive 3D circuit design it offers high efficiency, low crosstalk, and improves the heat dissipation. The modular cable system design with flat-ribbon cables makes cable management a breeze and results in a clean and tidy build. It uses the high grade Japanese capacitor which ensures and extended lifetime and excellent holdup times, in case of power fluctuation.
  • Less cables, less clutter
    VSM power supplies feature a design that allows you to only connect cables that your system needs. Fewer cables mean less mess and better airflow inside your case.
  • Quality you can see
    VSM PSUs feature high quality Japanese capacitors for many benefits including increased longevity, reduced ripple and electrical instabilities, and better efficiency and protection.
  • Compact power
    At only 140 mm (5.5 inches) long, VSM PSUs are compact, but are still in the standard ATX form factor. Its size is ideal for mini-ITX builds in cases like Cooler Master's Elite 130.
  • 80 PLUS savings
    With VSM's 80 PLUS Gold certification, enjoy great savings on your energy bill with over 90% efficiency.
  • Power chart
    Powerful single +12 V rail provides superior load balancing and graphics card compatibility.
Cooler Master VSM Series V750 - power supply - 750 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.31
80 PLUS Certification
80 PLUS Gold
United Kingdom
Input Voltage
AC 90-264 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
750 Watt
Output Current
+3.3V - 25 A , +5V - 22 A , +12V - 62 A , -12V - 0.3 A , +5V - 2.5 A
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin +12V with detachable 4 pin section , 4 x 8 pin PCI Express power with detachable 2 pin section , 8 x 15 pin Serial ATA power , 6 x 4 PIN internal power , 1 x 4 PIN mini-power connector
Modular Cable Management
Cooling System
120 mm fan
15 cm x 14 cm x 8.6 cm
5-year warranty
ATX12V 2.31
PSU Form Factor
ATX
United Kingdom
Input Voltage
AC 90-264 V
Frequency Required
50 - 60 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
750 Watt
Output Current
Efficiency
90%
80 PLUS Gold
MTBF
100,000 hours
Cooling System
120 mm fan
Overheat protection, over current protection, over voltage protection, overpower protection, undervoltage protection, short-circuit protection, single 12V rail, DC-DC technology
UL, TUV, BSMI, CCC, FCC, KCC, EAC, RCM
Limited warranty - 5 years
15 cm
14 cm
8.6 cm
