The Seidon 120V ver. 2 is the AIO watercooler that boasts an excellent value for performance. The compact radiator fits in virtually every case. Thanks to a premium Silencio FP fan with strong air pressure, Seidon can operate silently or unleash a powerful cooling storm at your command. Durable FEP Tubing provides the advantages of nearly no moisture absorption, high thermal stability and high pressure tolerance which all contribute to a long operating life.
- Cooler Master Seidon 120V ver.2 - processor liquid cooling system
- Product Type
- Processor liquid cooling system
- Compatibility
- LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket
- Heatsink Material
- Aluminium
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Loop dynamic bearing
- Rotation Speed
- 800-2400 rpm
- Air Flow
- 16.5-76 cfm
- Noise Level
- 6.5 - 27 dBA
- Power Connector
- 4-pin fan connector
- Rated Voltage
- 12 V
- Variable fan speed, Pulse-width modulation (PWM) support, Micro Channel Technology, Silencio FP fan
- Blue LED lighting
- 2-year warranty
- Product Type
Heatsink & Fan
- Compatible With
- Heatsink Material
- Aluminium
- Heatsink Dimensions
- 154 mm x 119 mm x 27 mm
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Rotation Speed
- 800-2400 rpm
- Air Flow
- 16.5-76 cfm
- Air Pressure
- 0.48-4.8 mm
- Noise Level
- 6.5 - 27 dBA
- Power Connector
- Rated Voltage
- 12 V
- Rated Current
- 0.1 A
- Power Consumption
- 1.2 W
- Blue LED lighting
- Limited warranty: - 2 years
