CoolerMaster Hyper 212 Evo - 4 Heatpipe, Tower CPU Cooler
Quicklinx: 8K32WS00 Mfr#: RR-212E-16PK-R1
The Hyper 212 EVO cooling systems are designed and optimized to provide the best user experience and cooling potential for a new generation of processors. The Hyper 212 EVO now features four Cooler Master patented Continuous Direct Contact (CDC) heat pipes that are tightly packed into a flat array on the CPU Cooler base. This acts as a virtual vapor chamber that dissipates a large amount of heat. The aluminum fin structure has been optimized to provide the perfect performance balance between high and low speed fan operations
Cooler Master Hyper 212 Evo - processor cooler
Processor cooler
Compatibility
LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, Socket FM1, LGA1150 Socket
Heatsink Material
Aluminium
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Long life sleeve bearing
Rotation Speed
600-1600 rpm
Air Flow
24.9-66.3 cfm
Noise Level
9 - 31 dBA
Power Connector
4-pin fan connector
Heat pipe technology, Pulse-width modulation (PWM) support
8 cm x 12 cm x 15.9 cm
0.58 kg
Processor cooler
8 cm
12 cm
15.9 cm
0.58 kg
Heatsink & Fan
Compatible With
Processor Compatibility
Core i7 , Core i7 Extreme Edition , Core i5 , Core i3 , Core 2 Extreme , Core 2 Quad , Core 2 Duo , Pentium , Celeron , Phenom II , Phenom X3 , Phenom X4 , Athlon II , Athlon , Sempron , Athlon X2
Heatsink Material
Aluminium
Heatsink Dimensions
159 mm x 116 mm x 51 mm
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Rotation Speed
600-1600 rpm
Air Flow
24.9-66.3 cfm
Air Pressure
0.3-1.7 mm
Noise Level
9 - 31 dBA
Power Connector
4-pin fan connector
