CoolerMaster HAF-X Full Tower (Extended ATX) Black
Quicklinx: 7BNWWS00 Mfr#: RC-942-KKN1
The much anticipated HAF X arrives as the flagship of the popular HAF (High Air Flow) series. Designed for performance systems, this chassis is able to house today's latest and hottest CPUs, motherboards, graphics cards and is even compatible with USB 3.0 devices. With specialized support and cooling for graphic cards, massive airflow with the help of up to four gigantic fans and easy access to installed components, this as close as it gets to a system builder's 'dream case'.
  • SATA Dock for easy installation without the need of removing side panel
  • Internal USB 3.0 on front I/O panel
  • Air duct to cool the latest graphic cards
  • Up to 1 x 230 mm red LED fan and 3 x 200 mm fans
  • 9 slots support triple VGA cards
  • Adjustable VGA card holder to support heavier GPU cards
  • Power supply partition to conceal cables
  • Advanced cable management with rubber grommets
  • Spacious interior for larger component parts
  • Rugged black coated interior
Cooler Master HAF X - tower - extended ATX
System cabinet
Tower
Windowed Side Panel
I/O Connectors
4 x USB , 1 x FireWire , 1 x eSATA , 1 x audio line-out , 1 x microphone
Installed Fans Qty
4
Supported Motherboards
ATX, microATX, Extended ATX
System Cabinet Features
Red LED
(ATX / PS/2)
23 cm x 59 cm x 55 cm
14.35 kg
Tower
Windowed Side Panel
Max Mainboard Size
Extended ATX
Internal Bays Qty
5
Front Accessible Bays Qty
8
Fans
Front: 1 x 23 cm - (1 installed) , Top: 2 x 20 cm - (1 installed) , Side: 1 x 20 cm - (1 installed) , Rear: 1 x 14 cm - (1 installed) , Internal: 1 x 12 cm - (0 installed) , Internal: 1 x 8 cm - (0 installed)
Red LED
Expansion Bays
6 (total) / 6 (free) x front accessible - 5.25" , 2 (total) / 2 (free) x front accessible - 2.5" , 5 (total) / 5 (free) x internal - 3.5"
Expansion Slots
9 x Expansion Slot
4 x USB , 1 x FireWire , 1 x eSATA , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack
Specification Compliance
ATX / PS/2
23 cm
59 cm
55 cm
14.35 kg
