CoolerMaster Elite 130 USB 3.0 High Airflow Mini-ITX Case
Quicklinx: 8ZCJWS00 Mfr#: RC-130-KKN1
Case Form Factor: Ultra small form factor
Motherboard Form Factor: Mini ITX
Colour: Black
22 in stock
£36.84 ex VAT
£44.20 inc VAT
The Elite 130 is an ultra compact case with support for full size high-end desktop components. It can accommodate the largest high-end VGAs, a 5.25" optical drive and up to 3 HDDs/5 SSDs. You can even install a 120 mm radiator in the front for extreme cooling. Thanks to a smart airflow system featuring 2 fans and the full mesh front panel it manages to still keep the system extremely cool.
Cooler Master Elite 130 - ultra small form factor - mini ITX
System cabinet
I/O Connectors
2 x USB 3.0 , 1 x USB 2.0 , 1 x microphone , 1 x audio line-out/headphones
Supported Motherboards
Mini-ITX
System Cabinet Features
Supports 120 mm radiator in front panel
No power supply
Specification Compliance
ATX / PS/2
24 cm x 37.75 cm x 20.5 cm
3.1 kg
Max Mainboard Size
Mini ITX
Mini-ITX
ATX / PS/2
Internal Bays Qty
4
Front Accessible Bays Qty
1
Cooling System
Front: 120 mm fan x 1 , Side: 80 mm fan x 1
CPU Cooler Max Height
65 mm
Video Card Max Length
343 mm
Expansion Bays
1 (total) / 1 (free) x front accessible - 5.25" , 2 (total) / 2 (free) x internal - 3.5" , 1 (total) / 1 (free) x internal - 2.5" , 1 (total) / 1 (free) x internal - 5.25"/ 3.5" shared , 3 (total) / 3 (free) x internal - 5.25"/ 2.5" shared
Expansion Slots
2
2 x USB 3.0 , 1 x USB 2.0 , 1 x microphone - mini-jack , 1 x audio line-out/headphones - mini-jack
No power supply
24 cm
37.75 cm
20.5 cm
3.1 kg
Colour: Black
Brand: CoolerMaster
Price Range Ex VAT: 0 - 50
