CoolerMaster Elite 120 Advanced - USB 3.0, Mini-ITX Case
Quicklinx: 8K3TWS00 Mfr#: RC-120A-KKN1
The Cooler Master Elite 120 Advanced is and ultra compact case with support for full size high-end desktop components. Other than conventional mini ITX cases, The Elite 120 Advanced supports more affordable, quiet, efficient and easily available full size ATX PSU's. It can accommodate even the largest ultra high-end VGAs, a 5.25" optical drive and up to 5 HDDs or SSDs. Thanks to a smart airflow system featuring 3 fans it manages to still keep the system cool and quiet. Topped off with a stylish brushed aluminum front, this is a compact case you don't want to hide.
Cooler Master Elite 120 Advanced - USFF - mini ITX
System cabinet
Ultra small form factor
I/O Connectors
2 x USB 2.0 , 1 x microphone , 1 x audio line-out , 1 x USB 3.0
Supported Motherboards
Mini-ITX
(ATX / PS/2)
24 cm x 40.14 cm x 20.74 cm
Max Mainboard Size
Mini ITX
Mini-ITX
Front Accessible Bays Qty
1
Cooling System
Front: 120 mm fan x 1 , Side: 80 x 80 x 15 mm fan x 1
Expansion Bays
1 (total) / 1 (free) x front accessible - 5.25" x 1/2H , Internal - 4x2.5"/ 4x1.8" / 2x3.5" shared , 1 (total) / 1 (free) x internal - 3.5" x 1/3H
Expansion Slots
2 x full-height
2 x USB 2.0 , 1 x microphone - mini-jack , 1 x audio line-out - mini-jack , 1 x USB 3.0
Specification Compliance
ATX / PS/2
Max Supported Qty
1
24 cm
40.14 cm
20.74 cm
