Cooler Master Hyper 612 Ver. 2 - Processor cooler - ( LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket, Socket FM2+, LGA2011-3 Socket ) - aluminium with copper base - 120 mm
- Cooler Master Hyper 612 Ver. 2 - processor cooler
- Product Type
- Processor cooler
- Compatibility
- LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket, Socket FM2+, LGA2011-3 Socket
- Heatsink Material
- Aluminium with copper base
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Rifle bearing
- Rotation Speed
- 800-1300 rpm
- Air Flow
- 26.6 - 44.2 cfm
- Noise Level
- 11 - 20 dBA
- Power Connector
- 4-pin fan connector
- Rated Voltage
- 12 V
- Pulse-width modulation (PWM) support, 6 copper heatpipes (6 mm), Continuous Direct Contact (CDC) technology, X-Vent technology
- 12.89 cm x 15.01 cm x 16.04 cm
- 2-year warranty
- Product Type
- Processor cooler
- 12.89 cm
- 15.01 cm
- 16.04 cm
Heatsink & Fan
- Compatible With
- Heatsink Material
- Heatsink Dimensions
- 160.4 mm x 139 mm x 102 mm
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Rifle bearing
- Rotation Speed
- 800-1300 rpm
- Air Flow
- 26.6 - 44.2 cfm
- Air Pressure
- 0.6 - 1.6 mm
- Noise Level
- 11 - 20 dBA
- Power Connector
- Rated Voltage
- 12 V
- Rated Current
- 0.09 A
- Power Consumption
- 1.08 W
- Mounting Kit
- Included
- Limited warranty: - 2 years
