CoolerMaster CM Storm Stryker USB 3.0  XL-ATX Case
Quicklinx: 8MWSWS00 Mfr#: SGC-5000W-KWN1
Built to be amongst the most agile full-towers, Stryker includes an ultra-strong travel-ready carrying handle. CM Storm Stryker has a stylish glossy finish on the case and included fans, windowed side panel, full dust filter coverage, a fan controller, an external SSD drive hot-swap dock and two uniquely designed modular hard drive cages. These features give CM Storm Stryker the ability to adapt to workstation or water-cooled gaming configurations easily.
Cooler Master CM Storm Stryker - tower - ATX
System cabinet
Tower
Windowed Side Panel
Black & white
Built-in Devices
External SATA X-Dock
I/O Connectors
2 x USB 2.0 , 2 x USB 3.0 , 1 x audio line-out , 1 x microphone
Supported Motherboards
ATX, microATX, XL-ATX
System Cabinet Features
Carrying handle, rotational drive cage, top panel dust filter, removable dust filter, fan speed controller, meshed front panel, floor dust filter, Storm Guard
No power supply (ATX12V / EPS12V / PS/2)
25 cm x 60.5 cm x 57.85 cm
13.7 kg
Tower
Windowed Side Panel
Max Mainboard Size
ATX
Internal Bays Qty
8
Front Accessible Bays Qty
9
Hot-Swap Bays Qty
1
Built-in Devices
Black & white
Cooling System
Front: 120 mm fan x 2 / 1200 rpm / 17 dBA / white LED , Top: 200 mm fan x 1 / 1000 rpm / 23 dBA / 2 x 120/140 mm fan supported , Rear: 140 mm fan x 1 / 1200 rpm / 19 dBA , Bottom: 120 mm fan mount x 2
Expansion Bays
9 (total) / 9 (free) x front accessible - 5.25" x 1/2H , 8 (total) / 8 (free) x internal - 3.5" x 1/3H , 13 (total) / 13 (free) x internal - 2.5"
Expansion Slots
10 x Expansion Slot
2 x USB 2.0 , 2 x USB 3.0 , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack
No power supply
Specification Compliance
Max Supported Qty
1
25 cm
60.5 cm
57.85 cm
13.7 kg
