CoolerMaster 700W Vanguard V700W 80plus Gold Fully Modular PSU
Quicklinx: 8RXLWS00 Mfr#: RS700-AFBAG1-UK
Cooler Master developed the V-series to re-ascertain its position as the worlds top power supply brand. It features outstanding efficiency, especially at typical low idle loads, excellent hold up times, voltage stability and ripple suppression. It only uses highest grade Japanese capacitors, most of them solid capacitors, as well as a massive high quality 42mm transformer.
And thanks to high quality FDB fans V-series PSUs are extremely cool and quiet. The V-series uses a fully modular cable system with beautiful all black, extra slim flat-ribbon cables. This makes cable management a breeze and results in nice looking clean builds with the best possible airflow.
Cooler Master V Series V700 - power supply - 700 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.31
80 PLUS Certification
80 PLUS Gold
United Kingdom
Input Voltage
AC 115/230 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
700 Watt
Output Current
+3.3V - 25 A , +5V - 25 A , +12V - 58 A , -12V - 0.5 A , +5VSB - 2.5 A
Input Connectors
1
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin +12V with detachable 4 pin section , 4 x 8 pin PCI Express power with detachable 2 pin section , 4 x 4 PIN internal power , 9 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector
Modular Cable Management
Cooling System
135 mm fan
15 cm x 17 cm x 8.6 cm
5-year warranty
ATX12V 2.31
PSU Form Factor
ATX
United Kingdom
Input Voltage
AC 115/230 V
Input Voltage Range
AC 90 - 264 V
Frequency Required
47 - 63 Hz
Input Connectors
1
Output Voltage
+3.3, +5, ±12 V
Power Capacity
700 Watt
Output Current
80 PLUS Gold
MTBF
100,000 hours
Cooling System
135 mm fan
Over voltage protection, overpower protection, undervoltage protection, short-circuit protection, thermal protection, fully modular
TUV, C-Tick, BSMI, GOST, CCC, FCC, KCC
Limited warranty - 5 years
15 cm
17 cm
8.6 cm
