CoolerMaster 693 Window Transparent Side Window Black Bezel Case
Quicklinx: 8ZCDWS00 Mfr#: CMS-693-KWN1
The exterior retains the curved metal mesh look the series is known for. The interior has been completely updated - the HDD/SSD combo cage can be switched between 3.5-inch or 2.5-inch drives by adjustable trays without any screw. There's enough room for a 240 mm liquid cooling radiator at the top or front, 120 mm in the rear and supports up to 9 fans, including 3 large 200 mm fans for extreme airflow. And cleaning is hassle free thanks to the multiple dust filters at the bottom, top, and front.
Cooler Master CM 690 III - tower - ATX
System cabinet
Tower
Windowed Side Panel
Midnight black
I/O Connectors
2 x USB 3.0 , 2 x USB 2.0 , 1 x audio line-out/headphones , 1 x microphone
Supported Motherboards
ATX, microATX
System Cabinet Features
Top panel dust filter, removable dust filter, meshed front panel, front dust filter, liquid cooling holes, rear dust filter, meshed top, cable management system, supports 240 mm radiator in front panel, supports 240 mm radiator in top, supports 120 mm radiator in rear
No power supply (ATX / PS/2)
23 cm x 50.7 cm x 50.2 cm
8.7 kg
Tower
Windowed Side Panel
Max Mainboard Size
ATX
ATX, microATX
Internal Bays Qty
10
Front Accessible Bays Qty
3
Midnight black
Cooling System
Top: 120/140 mm fan mount x 1 / 1 x 200 mm fan supported , Front: 200 mm fan x 1 / 2 x 120/140 mm or 1 x 180 mm fan supported , Rear: 120 mm fan x 1 , Bottom: 120 mm fan mount x 1 , Internal: 120 mm fan mount x 1
CPU Cooler Max Height
171 mm
Video Card Max Length
423 mm
Expansion Bays
3 (total) / 3 (free) x front accessible - 5.25" , 7 (total) / 7 (free) x internal - 2.5" / 3.5" shared , 3 (total) / 3 (free) x internal - 2.5"
Expansion Slots
8
2 x USB 3.0 , 2 x USB 2.0 , 1 x audio line-out/headphones - mini-jack , 1 x microphone - mini-jack
3.5" to 2.5" bay adapter
No power supply
Specification Compliance
ATX / PS/2
23 cm
50.7 cm
50.2 cm
8.7 kg
