CoolerMaster 550W VM Series V550S 80 Plus Gold PS
Quicklinx: 9FR6WS00 Mfr#: RS550-AMAAG1-UK
Developed to improve efficiency and increase heat dissipation, VS series PSU is manufactured with a unique 3D circuit design. This special design minimizes unnecessary internal cabling which results in lower crosstalk and signal noise. VS series PSU features a single, powerful rail. High-grade Japanese capacitors help extend overall PSU system life and create excellent holdup times. A firm 80 PLUS Gold certification and solid performance over long periods of use are the net result of these many improvements.
  • Modular cable system
    Use the cables you need, no unnecessary cable mess! Building a clean and tidy system with excellent airflow has never been this easy and convenient.
  • Unique 3D circuit design
    The CM exclusive circuit design offers high efficiency and improves the heat dissipation. It reduces the unnecessary cables which results in much lower crosstalk, signal noise and improves airflow.
  • Custom DC-DC module
    Custom 12 V to 3.3 V and 5 V module design offers notably higher efficiency and voltage stability than other designs.
Cooler Master VS Series V550S - power supply - 550 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.31
80 PLUS Certification
80 PLUS Gold
Europe
Input Voltage
AC 90-264 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
550 Watt
Output Current
+3.3V - 20 A , +5V - 20 A , +12V - 45 A , -12V - 0.3 A , +5VSB - 2.5 A
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin +12V with detachable 4 pin section , 2 x 8 pin PCI Express power with detachable 2 pin section , 6 x 15 pin Serial ATA power , 3 x 4 PIN internal power , 1 x 4 PIN mini-power connector
Modular Cable Management
15 cm x 14 cm x 8.6 cm
5-year warranty
ATX12V 2.31
PSU Form Factor
ATX
Europe
Input Voltage
AC 90-264 V
Frequency Required
47 - 63 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
550 Watt
Output Current
Efficiency
92%
80 PLUS Gold
MTBF
100,000 hours
Overheat protection, over current protection, over voltage protection, overpower protection, undervoltage protection, single 12V rail, DC-DC technology
UL, TUV, BSMI, CCC, FCC, KCC, EAC
Limited warranty - 5 years
15 cm
14 cm
8.6 cm
Shipping Width
26.6 cm
Shipping Depth
19.4 cm
Shipping Height
19.2 cm
