From the premium line of products, Rokku from lock or rock in Japanese, represents a design of Tablet Enclosure with dual locks and a rock solid frame.
The Rokku design includes high security cylinder lock mechanism and a recessed frame for a full tamper proof enclosure. Access to the On/Off and volume buttons are blocked while still allowing for charging and limited audio port access.
Constructed of high grade aluminum makes the Rokku iPad enclosure extremely lightweight and durable at the same time. With soft edges and rounded corners the aesthetic of this enclosure is very appealing and fits all display environments.
Although very thin at only 3cm (1.18 in) deep, the sunken frame design allows for full cable management adding another level security to your Tablet.
The Rokku Tablet enclosure includes a standard 100mm x 100mm VESA pattern which will allow it to be mounted to flat surfaces and the full line of mounts.
Enhanced security
The Rokku iPad / Galaxy Security Lock tablet Enclosure features an anti-theft design, providing peace of mind and ensuring your device remains secure in public spaces or high-traffic areas. -
Versatile placement
Designed to be wall-mountable, this enclosure offers flexibility in placement, allowing for optimal viewing and interaction in various settings, from retail to educational environments.
- Compulocks Rokku iPad / Galaxy Security Lock tablet Enclosure enclosure - Anti-Theft - for tablet - black
- Product Type
- Enclosure (Anti-Theft) - wall-mountable
- Recommended Use
- Tablet
- Black
- Designed For
- Samsung Galaxy Tab A (9.7 in), Tab S2 (9.7 in), Tab S3 (9.7 in)
- Black
AV Furniture
- Enclosure
- Design
- Anti-Theft
- Recommended Use
- Tablet
- Placing / Mounting
- Wall-mountable
- Designed For
