Compaq Modular Power Distribution Unt
Quicklinx: 2J4FWS00 Mfr#: 252663-B24
Is your data center lacking sufficient outlet receptacles or flexibility in rack space? Is cable management a problem? HP Modular PDUs have a unique architecture designed specifically for data center customers who want to maximize power distribution and space efficiencies in the rack. Available in a small form factor with flexible mounting options, installation is quick and easy with all brackets, accessories and installation guides included. Modular PDUs consist of two building blocks the Core Unit (core) and the Extension Bar(s) (sticks). The Core Unit is 1U/0U, and the Extension Bars mount directly to the frame of the rack in multiple locations. Single phase models are available up to 40 amps and can have up to 28 outlets divided across 4 extension bars. Three phase models are core only units with 6 x C19 outlets that can be connected to optional extension bars or directly to components such as BladeSystems enclosures.
  • Unique modular design architecture
    HP Modular PDUs modular design architecture with flexible mounting options is designed for data centers with limited space and outlets.HP Modular PDUs ship with up to 4 extension bars that can be plugged into the Core Unit and can be mounted directly to the rack-frame or the rack extension unit.The HP Modular PDUs are quick and easy to install with all brackets, accessories and installation guides included. Power cords are attached for quick installation.The HP Modular PDUs allows for consolidation of cords making cord management easy and efficient. All of the HP Modular PDUs offer superior cable management and accessibility.HP Modular PDUs single phase models are available up to 40 amps and can have up to 28 outlets divided across 4 extension bars. Three phase models are core only units with 6 x C19 outlets that can be connected to optional extension bars or directly to components such as BladeSystems enclosures.
  • Our Basic PDUs get Power where you Need it to Go – and Keep it There
    HPE Basic Power Distribution Units Horizontal/Modular PDU Models can be installed in any U position in your rack.Integrated cord retention to connect the right cord to the right outlet, quickly and easily.
  • Vertical PDU Models use Button and Keyhole Mounting for Simple Drop in Install
    HPE Basic Power Distribution Units vertical form factor models have a wide range of single and three-phase options providing up to 22kVA of output power.Mounts vertically on either side in the rear of the rack using industry standard button and keyhole mounting. Standard mounting faces the outlet towards the rear of the rack preventing interference in the maintenance zone between rear RETMA rails.Using the optional configuration of facing the outlets into the rack, multiple PDUs can be mounted on one side of the rack for higher power density.
  • Getting Power Where it Needs to go has Never Been Easier, from Purchase to Prime Time
    HPE Basic Power Distribution Units have a wide range of mounting options to fit every application. Power where you need it, plus more room for compute.Highest-density PDUs on market means more power and less headache for even the most demanding compute applications.Tool-less installation, low profile and modular extensions simplify configuration and reduce time to deployment.HPE Foundation Care means your power isn't the only thing that's protected – the warranty from your HPE servers extends to your PDUs.
HPE - power distribution strip - 3680 VA
Power distribution strip - rack-mountable
8.2 kg
Input Voltage
AC 200/240 V
Power Capacity
3680 VA
Input Connectors
1 x power IEC 60320 C20
Output connectors
16 x power IEC 60320 C13
44.5 cm x 14.2 cm x 4.1 cm
3-year warranty
HPE 10XXX G2; BladeSystem bc1000; Enterprise Modular Library 71e LTO-4; ProLiant DL320e Gen8, DL360e Gen8, DL360p Gen8, DL380 G6, DL380e Gen8, DL385p Gen8, DL560 Gen8, ML310e Gen8, ML350e Gen8, Moonshot Server, Moonshot Server Starter System, SL270s Gen8, SL390s G7; Rack; UPS R12000, R7000, R8000
Input Voltage
AC 200/240 V
Frequency Required
50/60 Hz
Input Connectors
Power Capacity
3680 VA
Circuit Protection
Circuit breaker
4 x power cable - external
Rack Mounting Kit
Included
UL, cUL, NOM
Limited warranty - 3 years
10 °C
50 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
10 - 90%
Humidity Range Storage
5 - 95%
44.5 cm
14.2 cm
4.1 cm
8.2 kg
HP UPS R/T3000 G2 Detachable Cord High Voltage, R1500 G3, R5000 , HPE 10642 G2 1200mm deep Shock Rack, 10647 G2 1200mm deep Shock Rack , HPE BladeSystem bc1000 Blade PC , HPE Enterprise Modular Library 71e LTO-4 Ultrium 1840 , HPE ProLiant DL120 G7, DL120 G7 Base, DL120 G7 Entry, DL120 G7 Performance, DL160 Gen8, DL160 Gen8 Entry, DL160 Gen8 Performance, DL320e Gen8, DL320e Gen8 Base, DL320e Gen8 Entry, DL320e Gen8 Performance, DL360 G7 Special Server, DL360e Gen8, DL360e Gen8 Base, DL360e Gen8 Entry, DL360e Gen8 Performance, DL360e Gen8 Special Server, DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 CMS, DL360p Gen8 Entry, DL360p Gen8 High Performance, DL380 G6, DL380 G7 Special Server, DL380e Gen8 Base, DL380e Gen8 Entry, DL380e Gen8 High Performance, DL380e Gen8 Storage, DL380p Gen8, DL380p Gen8 Base, DL380p Gen8 Entry, DL380p Gen8 High Performance, DL380p Gen8 Special, DL385p Gen8, DL385p Gen8 Dedicated Workload, DL385p Gen8 Entry, DL385p Gen8 Maximized Consolidation, DL385p Gen8 Storage, DL385p Gen8 Storage Centric, DL560 Gen8, DL580 G5 Highly Serviceable Tower, ML310e Gen8, ML310e Gen8 v2, ML310e Gen8 v2 Base, ML310e Gen8 v2 Enty, ML310e Gen8 v2 Performance, ML350e Gen8, ML350e Gen8 Base, ML350e Gen8 Entry, ML350e Gen8 Performance, ML350e Gen8 v2, ML370 G6 Special Server, Moonshot Server, Moonshot Server Starter System, SL170s G6 Base Left Half Width tray, SL230s Gen8 1U Left Half Width Tray, SL230s Gen8 1U Right Half Width Tray, SL230s Gen8 Base 1U Left Tray Server, SL230s Gen8 Base 1U Right Tray Server, SL250s Gen8 Base 2U Left Half Width Tray, SL250s Gen8 Base 2U Right Half Width Tray, SL270s Gen8 Base 4U Left Half Width Tray, SL270s Gen8 Base 4U Right Half Width Tray, SL390s G7 2U Left Half Tray Node Server, SL390s G7 Base 4U Left Half Width tray, SL390s G7 Performance 4U Left Half Width tray, SL390s G7 Performance 4U Right Half Width tray , HPE Rack , HPE UPS R12000/3, R7000, R8000/3
