Clevertouch 65"  USB HDMI DVI-D VGA LED Display
Quicklinx: BBW7WS00 Mfr#: 1541009
  • 1080p
The powerful touchscreen technology is integrated into the screen enabling it to be dual touch, allowing multiple users. The Clevertouch range does not require drivers, calibration or set up. The crystal clear resolution and high brightness display means that images are clearly visible and unlike projection based interactive solutions, there is no shadowing.
The Clevertouch LED features a slimmer bezel, lower power consumption and a lighter weight, whilst still being as tough and durable as the Clevertouch LCD.
Clevertouch Plus 65" LED-backlit LCD display - Full HD
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
65"
Resolution
1920 x 1080
Display Format
1080p
Video Interface
Composite, HDMI
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Storage Capacity
8 GB Flash
USB
4 ports
Remote control, pen stylus, CleverLynx with Wordwall, DisplayNote Presenter Licence
Voltage
265 Watt
Power Consumption Stand by
0.5 Watt
154.5 cm x 10.5 cm x 94.2 cm
72 kg
265 Watt
Diagonal Class
65"
Combined With
Touchscreen
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
Composite, HDMI
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
HDCP Compatible
154.5 cm
10.5 cm
94.2 cm
72 kg
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-glare
Colour Depth
10-bit colour
Image Contrast Ratio
4000:1
Brightness
360 cd/m²
Viewing Angle
178 degrees
Touchpoints Qty
10
Response Time
8 ms
Backlight Life
50,000 hour(s)
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Media Player
USB Port
USB Ports Qty
4
Configuration
ARM Cortex-A9 Dual-Core - 1.5 GB DDR3 - 8 GB Flash
Operating System
Android OS 4.2.1
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
Connect & Share
Wireless HD Ready (WHDI)
Connector Type
3 x VGA input , 3 x audio input , Serial , 3 x USB 2.0 , USB 3.0 , LAN , 3 x HDMI input , Composite video input , VGA output , Audio line-in , Headphones , Digital audio input (coaxial)
Pen stylus, CleverLynx with Wordwall, DisplayNote Presenter Licence
VGA cable - 5 m , USB cable - 5 m , Audio cable - 5 m , HDMI cable - 1.5 m
Power supply
Input Voltage
0.5 Watt
Width (Shipping)
170 cm
Depth (Shipping)
21.5 cm
Height (Shipping)
110 cm
Weight (Shipping)
82 kg
