Cisco Wireless-G IP Phone
Quicklinx: 5FFGWS00 Mfr#: WIP310-G2
The Cisco WIP310 Wireless-G IP Phone enables high-quality voice over IP (VoIP) service through a Wireless-G network.
The Cisco WIP310 operates in the 2.4-GHz band and supports 802.11b/g and the VoIP Session Initiation Protocol (SIP). The large, full-color high-resolution display features an intuitive user interface that enables users to easily and quickly configure the handset with network access using Wi-Fi Protected Setup (WPS).
WPS is a fast, highly secure way of connecting the Cisco WIP310 IP phone with any standards-based Wireless-G broadband router. Just press the WPS button and your connection will automatically be configured and secured with a custom service set identifier (SSID) using powerful Wi-Fi Protected Access (WPA) encryption. Within seconds you have successfully set up a highly secure connection.
The Cisco WIP310 uses the same trusted and proven provisioning capabilities presently being used to deploy other popular Cisco voice products for small and medium-sized businesses on a massive scale. Customers purchasing VoIP service from a service provider and using the Cisco WIP310 can be quickly provisioned over a Wi-Fi connection, receiving their configuration profile securely right to the handset via a Trivial File Transfer Protocol (TFTP), HTTP, or HTTPS download.
The included telephone base accentuates the modern design of the handset and provides hands-free convenience when using the built-in speakerphone. The Cisco WIP310 supports many features such as caller ID, call forwarding, call transfer, and three-way conferencing and can store 200 records in its phone book.
Benefit with low-cost VoIP service and access to any Wireless-G network using the WIP310 Wireless-G IP Phone from Cisco.
  • Efficient power usage
    Equipped with a rechargeable 860 mAh lithium-ion battery, this device ensures up to 180 minutes of talk time and up to 40 hours of standby time, minimizing the need for frequent recharging.
  • Crystal clear display
    Features a 1.8-inch LCD display with backlight, offering a resolution of 128 x 160 pixels. This compact yet clear screen displays information in vivid color, supporting up to 65000 colors for enhanced readability.
  • Enhanced connectivity
    Supports VoIP with SIP and SIP v2 protocols, facilitating efficient and reliable communication over the Internet. With options for DHCP and static IP address assignment, it integrates seamlessly into a variety of network environments.
  • Robust security features
    Provides multiple layers of security, including 128-bit WEP, 64-bit WEP, WPA, and WPA2, to protect your communications from unauthorized access and ensure privacy.
  • Comprehensive call management
    Offers a suite of call services including call forwarding, call hold, call transfer, call waiting, caller ID, and voice mail capability. Combined with a built-in clock, polyphonic ringer, and speakerphone, it enhances the user experience by streamlining call handling.
Cisco Small Business WIP310 - wireless VoIP phone - 3-way call capability
Wireless VoIP phone
Total Number of Wireless Handsets
1
Cordless Phone Standard
IEEE 802.11g (Wi-Fi)
VoIP Protocols
SIP, SIP v2
Voice Codecs
G.729ab, G.711u, G.711a, G.726
Speakerphone
Caller ID
Voice Mail Capability
Call Services
Voice Mail, Caller ID, Call Waiting, Call Forwarding, Call Transfer, Call Hold
Display
LCD display - colour - Yes
Wireless VoIP phone
1
Phone Features
Call Services
Max Handset Operating Distance
100 m
Max Handset Operating Distance (Outdoor)
300 m
Dialer Type
Keypad
Dialer Location
Handset
Conference Call Capability
3-way
Speakerphone
Short Messaging Service (SMS)
Menu Operation
Function Buttons
Speakerphone button, directory button
Volume Control
Ringer Control
Polyphonic Ringer
Lighted Keypad
Firmware Upgradable
Additional Functions
Built-in clock
Additional Features
Key lock, built-in web server
IP Telephony
VoIP
VoIP Protocols
SIP, SIP v2
Voice Codecs
IP Address Assignment
DHCP, static
Security
128-bit WEP, 64-bit WEP, WPA, WPA2
Network Protocols
IP, TCP, TFTP, UDP, HTTP
Voice Features
Echo cancellation (ECN)
Network Features
Network Address Translation (NAT)
Phone Memory
Phone Directory Capacity
200 names & numbers
Display
Display Location
Handset
Diagonal Size
1.8"
Display Resolution
128 x 160 pixels
Colour Depth
16-bit (65000 colours)
Backlit
Aerial
Internal
DC power input / mini-USB Type B , Headset jack / sub-mini-phone 2.5mm
USB cable
Power adapter, phone charging stand
FCC
Phone charging stand + power adaptor - external
860 mAh
Rechargeable - Lithium Ion
Talk Time
Up to 180 min
Standby Time
Up to 40 h
Dimensions & Weight (Handset)
4.4 cm
2.5 cm
14.9 cm
110 g
Resources
The following resources are available for the Cisco Wireless-G IP Phone
