Cisco Wireless Access Point
Quicklinx: DRTDWS00 Mfr#: WAP571-E-K9
Type: Radio access point
Connectivity: Wireless
Speed: 1.9Gbps
Protocol: IEEE 802.11a, IEEE 802.11ac, IEEE 802.11b, IEEE 802.11g + 1 more
Compatibility: PC, Unix
  • IEEE 802.11n
11 in stock
£143.22 ex VAT
£171.86 inc VAT
Get exceptional performance, faster connection, and wider coverage on your mobile devices. The WAP571 access point has built-in controller software for managing multiple access points. Its intuitive web-bases configuration allows you to set it up in just minutes.
Cisco Small Business WAP571 - radio access point
Radio access point
External
United Arab Emirates, South Africa, Vietnam, Hong Kong, Thailand, United Kingdom, Europe, Turkey
RAM
GB 256
Flash Memory
128 MB
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Connection / user qty: 200 , Concurrent users per radio: 50 , Maximum number of access points (per cluster): 16 , Maximum number of configured SSIDs: 16
Wall/ceiling mounting plate
Power Over Ethernet (PoE) Supported
PoE+
23 cm x 23 cm x 4 cm
778 g
Radio access point
23 cm
23 cm
4 cm
778 g
Processor / Memory / Storage
RAM
256 GB
Flash Memory
128 MB
External
Wireless
Data Transfer Rate
1.9 Gbps
Spread Spectrum Method
OFDM, DSSS
Network / Transport Protocol
NTP, DHCP, Bonjour
Remote Management Protocol
SNMP 3, HTTP, HTTPS
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Status
Auto-sensing per device, load balancing, VLAN support, Syslog support, E-mail alert, IPv6 support, DFS support, Wireless Distribution System (WDS) support, firmware upgradable, Spanning Tree Protocol (STP) support, Wi-Fi Multimedia (WMM) support, Auto Channel Select (ACS), event log, Access Control List (ACL) support, Quality of Service (QoS), Multiple SSID support, wireless bridge mode, reset button, IPv4 support, 3T3R MIMO technology, rogue access point detection, DHCP client, Energy Efficient Ethernet, security lock slot (cable lock sold separately), 802.1x authentication, Link Aggregation, network diagnostics, SSID to VLAN mapping
Encryption Algorithm
WPA, WPA2, WPA-Enterprise, WPA2-Enterprise
Authentication Method
RADIUS, Radio Service Set ID (SSID)
IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11e, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac
Aerial
Antenna
Internal
Antenna Qty
6
1 x 1000Base-T (PoE+) - RJ-45 , 1 x 1000Base-T (management) - RJ-45
1 x network cable
ICES-003, FCC Part 15.247, RSS-210, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15.107, FCC Part 15.109, FCC Part 15.407, EMI, EN 300 328, EN 301 489-1, AS/NZS 4268.2003, EN 301 893, CAN/CSA-C22.2 No. 60950-1, EN 301 489-17
PoE+
18 Watt
OS Provided
Linux
Limited warranty - lifetime
10 - 85% (non-condensing)
Speed: 1.9Gbps
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: PC
Compatibility: Unix
Brand: Cisco
Price Range Ex VAT: 100 - 150
