Cisco Gigabit Ethernet WAN Modules bring high-density Ethernet connectivity to the Cisco 4000 Series Integrated Services Routers (ISRs). Providing maximum flexibility, the modules accelerate applications such as Ethernet WAN access, inter-VLAN routing, and high-speed connectivity to LAN switches and servers.
Enhanced connectivity
This WAN Network Interface Module offers wired connectivity, ensuring stable and reliable network connections for PCs. Its plug-in module form factor allows for easy installation and integration into existing systems, providing a seamless upgrade path for enhancing network performance. -
PC compatibility
Designed specifically with PC compatibility in mind, this module ensures a hassle-free setup and operation. Users can expect a smooth integration process, making it an ideal choice for upgrading PC network capabilities without the need for extensive modifications.
- Cisco WAN Network Interface Module - expansion module - combo Gigabit SFP x 2
- Expansion module
- Form Factor
- Plug-in module
- Ports
- Combo Gigabit SFP x 2
- 8.9 cm x 18.4 cm x 3.2 cm
- 252 g
- Data Link Protocol
- 1GbE
- Designed For
- Cisco 4451-X Integrated Services Router, 4451-X Integrated Services Router Security Bundle, 4451-X Integrated Services Router Voice and Video Bundle, 4451-X Integrated Services Router Voice Security Bundle
- Expansion module
- Form Factor
- Plug-in module
- Ports
- Connectivity Technology
- Wired
- Gigabit Ethernet
- 2 x 1000Base-T - RJ-45 , 2 x 1000Base-X - SFP (mini-GBIC)
- 8.9 cm
- 18.4 cm
- 3.2 cm
- 252 g
- 0 °C
- 40 °C
- 5 - 85%
- Designed For
