Cisco WAN Network Interface Module - Expansion module
Quicklinx: DWQBWS00 Mfr#: NIM-1GE-CU-SFP=
Type: Modules
£661.28 ex VAT
£793.53 inc VAT
Cisco Gigabit Ethernet WAN Modules bring high-density Ethernet connectivity to the Cisco 4000 Series Integrated Services Routers (ISRs). Providing maximum flexibility, the modules accelerate applications such as Ethernet WAN access, inter-VLAN routing, and high-speed connectivity to LAN switches and servers.
  • Enhanced connectivity
    This WAN Network Interface Module offers wired connectivity, ensuring stable and reliable network connections for PCs. Its plug-in module form factor allows for easy installation and integration into existing systems, providing a seamless upgrade path for enhancing network performance.
  • PC compatibility
    Designed specifically with PC compatibility in mind, this module ensures a hassle-free setup and operation. Users can expect a smooth integration process, making it an ideal choice for upgrading PC network capabilities without the need for extensive modifications.
Cisco WAN Network Interface Module - expansion module - combo Gigabit SFP x 1
Expansion module
Plug-in module
Ports
Combo Gigabit SFP x 1
8.9 cm x 18.4 cm x 3.2 cm
252 g
1GbE
Expansion module
Plug-in module
Ports
Wired
Gigabit Ethernet
1 x 1000Base-T - RJ-45 ¦ 1 x 1000Base-X - SFP (mini-GBIC)
8.9 cm
18.4 cm
3.2 cm
252 g
5 - 85%
Type: Modules
Brand: Cisco
Price Range Ex VAT: £500 - £750
