The Cisco VG202XM voice gateways are analog voice gateways for the service provider, commercial, and enterprise unified communication markets. These voice gateways provide voice connectivity to devices such as analog phones, fax machines, and modems.
The Cisco VG202XM voice gateways provide support for 2-FXS ports and parity with Cisco IOS fax/modem, security, and Session Initiation Protocol (SIP) features. These voice gateways can be configured with Cisco Unified Communications Manager Express (CUCME) or Cisco Unified Communications Manager (CUCM).
Robust connectivity
Equipped with Fast Ethernet and support for multiple VoIP protocols including SIP, SCCP, and H.323 v4, the Cisco VG202XM ensures seamless integration into existing networks, providing reliable voice communications over IP. -
Enhanced voice quality
Featuring advanced voice codecs such as G.711, G.729a, and T.38, this analog voice gateway delivers clear, high-quality voice transmission, minimizing latency and packet loss. -
Secure communication
With support for RADIUS and TACACS+ authentication methods, alongside a comprehensive suite of compliance standards including FCC, UL 60950, and more, the Cisco VG202XM offers secure voice communication solutions that meet rigorous industry requirements. -
Durable design
Boasting an impressive MTBF of 200,000 hours and designed to operate within a wide range of environmental conditions, this device ensures reliability and longevity in various operational settings. -
Efficient management
This voice gateway offers extensive remote management capabilities through SNMP 3, HTTP, Telnet, and more, allowing for efficient configuration and monitoring of voice services.
- Cisco VG202XM Analog Voice Gateway - VoIP phone adapter
- Form Factor
- External
- RAM
- 256 MB
- Flash Memory
- 128 MB
- Data Link Protocol
- Ethernet, Fast Ethernet
- VoIP Protocols
- MGCP, SCCP, SIP, H.323 v4, RTP, SRTP
- Telephony Interfaces
- 2 phone (FXS)
- Power
- AC 120/230 V (50/60 Hz)
- 22.38 cm x 20.65 cm x 4.52 cm
- 1.351 kg
- 22.38 cm
- 20.65 cm
- 4.52 cm
- 1.351 kg
Processor / Memory / Storage
- RAM
- 256 MB DDR2 SDRAM
- Flash Memory
- 128 MB
- Form Factor
- External
- Connectivity Technology
- Wired
- DHCP, DNS
- Routing Protocol
- HSRP
- Remote Management Protocol
- Telnet, SNMP 3, HTTP, TFTP, CLI
- Wall mountable, RADIUS support
- Authentication Method
- RADIUS, TACACS+
IP Telephony
- VoIP Protocols
- Voice Codecs
- G.711, G.729a, T.38
- 2 phone (FXS)
- IP Telephony Features
- Caller ID, call waiting, automatic fax/modem detection and pass-through, call hold, call transfer
- 2 x 100Base-TX - RJ-45 , 1 x management - RJ-45 , 1 x management , 2 x modem - RJ-11
- MTBF
- 200,000 hours
- CISPR 22 Class B, CISPR 24, EN 61000-3-2, IEC 60950, EN 61000-3-3, EN55024, UL 60950, EN50082-1, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, FCC Part 15 B, EN 60950-1, AS/NZS 60950, CAN/CSA C22.2 No. 60950, VCCI Class B, EN 300 386
- Power Device
- External power adapter
- Voltage Required
- 30 Watt
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £13.78 |
