Cisco Unified SIPPhone 3905
Quicklinx: D4YKWS00 Mfr#: CP-3905=
11 In Stock
£92.87 ex VAT
£111.44 inc VAT
The Cisco Unified SIP Phone 3905 is a cost-effective, entry-level IP phone that addresses the need for basic voice communications with common Cisco Unified Communications features in an attractive design that is also budget-friendly. The phone can fill the communication needs of cubicle, retail, classroom, manufacturing floor and hallway, as well as various wall-mounted deployments.
The single-line Cisco Unified SIP Phone 3905 supports two calls per line. Fixed keys for redial, transfer, and hold/resume, along with a full-duplex speakerphone and two-line display, which comes standard, deliver a more productive, easier-to-use, and flexible endpoint experience. With its dual-port 10/100 Ethernet switch for network and PC connections, the Cisco Unified SIP Phone 3905 offers IT organizations a cost-effective solution to reduce cabling infrastructure and administration costs at the desktop. The phone is also eco-friendly, taking advantage of reground and recyclable plastics to deliver a more earth-responsible solution.
  • Ergonomic design
    The phone offers an easy-to-use interface and provides a traditional telephony-like user experience.
  • Display
    A graphical monochrome display with a resolution of 128 x 32 pixels provides a scrollable two-line intuitive access to phone services and configuration.
  • Foot stand
    A foldable single-position foot stand offers optimum display viewing and comfortable use of keys.
  • Wall mountable
    You can fold the foot stand for wall mounting, with mounting holes located on the base of the phone.
  • Speakerphone
    A full-duplex speakerphone allows for flexibility in placing and receiving calls.
  • Volume control
    The volume control toggle makes it easy to adjust the volume of the handset, speakerphone, and ringer.
  • Ethernet switch
    The phone has a 10/100Base-T Ethernet connection through two RJ-45 ports, one for the LAN connection and the other for connecting a downstream Ethernet device such as a PC.
Cisco Unified SIP Phone 3905 - VoIP phone
VoIP phone
Main Features
Multiple VoIP protocol support, integrated Ethernet switch
VoIP Protocols
SIP, RTCP
Voice Codecs
G.729, G.729a, G.729ab, G.711u, G.711a
Speakerphone
Yes (digital duplex)
Caller ID
Call Services
Caller ID, Call Waiting, Call Forwarding, Call Transfer, Call Hold, Message Waiting Capability
Display
LCD display - monochrome
Network Ports Qty
2 x Ethernet 10Base-T/100Base-TX
Compatible Software
Cisco Unified Communications Manager 7.1 or later
Body Colour
Charcoal
1-year warranty
VoIP phone
Body Colour
Charcoal
Phone Features
Call Services
Dialer Type
Keypad
Dialer Location
Base
Conference Call Capability
Speakerphone
Function Buttons
Speakerphone button, transfer button, mute button, hold button, auto redial button
Volume Control
Ringer Control
Indicators
Voice message waiting indicator
Firmware Upgradable
Additional Features
Music on hold, built-in web server
IP Telephony
Main Features
VoIP
VoIP Protocols
SIP, RTCP
Voice Codecs
IP Address Assignment
DHCP, static
Power Over Ethernet (PoE) Support
Network Protocols
TFTP, DNS, RTCP
Network Ports Qty
Compatible Software
Voice Features
Comfort noise generation (CNG), voice activity detection (VAD)
Display
Display Location
Base
Line Qty
2
Display Resolution
128 x 32 pixels
Display Languages
Danish, Hebrew, Hungarian, Czech, Croatian, Slovenian, Thai, Slovak, Brazilian Portuguese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Latvian, Lithuanian, Estonian, Serbian, Romanian, Catalan, Japanese, Chinese, Korean
RAM
32 MB
Hearing Aid Compatible
Placing / Mounting
Wall-mountable, table-top
Also Included
4 MB
CISPR 22 Class B, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, UL 60950 Third Edition, EN55022 Class B, ICES-003 Class B, DR PTC220, AS/ACIF S004, CS-03, FCC CFR47 Part 68, FCC CFR47 Part 15 B, GB 4943, AS/NZS 60950, HAC (Hearing Aid Compatible), CSA C22.2 No. 60950-1 Second Edition, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, VCCI Class B, KN24, KCC KN22 Class B, AS/ACIF S040
Dimensions & Weight (Base)
15 cm
20.5 cm
5.35 cm
594.3 g
Limited warranty - 1 year
Brand: Cisco
