CISCO UNIFIED IP PHONE 7942
Quicklinx: 74VJWS00 Mfr#: CP-7942G=
The Cisco Unified IP Phone 7942G is a full-featured IP phone with speakerphone and handset designed for wideband audio. It is intended to meet the needs of needs of transaction-type workers with significant phone traffic. It has two programmable backlit line/feature buttons and four interactive soft keys that guide you through all call features and functions. The phone has a large, 4-bit grayscale graphical LCD that provides features such as date and time, calling party name, calling party number, digits dialed, and presence information. The crisp graphic capability of the display allows for the inclusion of higher value, more visibly rich Extensible Markup Language (XML) applications, and support for localization requiring double-byte Unicode encoding for fonts. A hands-free speakerphone and handset designed for hi-fidelity wideband audio are standard on the Cisco Unified IP Phone 7942G, as is a built-in headset connection and an integrated Ethernet switch.
Cisco Unified IP Phone 7942G - VoIP phone
VoIP phone
Main Features
Integrated Ethernet switch
VoIP Protocols
SCCP, SIP
Voice Codecs
G.722, G.729a, G.729ab, G.711u, G.711a, iLBC
Speakerphone
Yes (digital duplex)
Voice Mail Capability
Call Services
Voice Mail
Display
LCD display - monochrome
Network Ports Qty
2 x Ethernet 10Base-T/100Base-TX
Body Colour
Silver, dark grey
VoIP phone
Body Colour
Silver, dark grey
Body Material
ABS plastic
Phone Features
Call Services
Voice Mail
Dialer Type
Keypad
Dialer Location
Base
Conference Call Capability
Speakerphone
Menu Operation
Function Buttons
Speakerphone button, headset button, menu navigation keys, mute button
Programmable Buttons Qty
2
Volume Control
Ringer Control
Ring Tones
24
Firmware Upgradable
Additional Functions
Web browser
IP Telephony
Main Features
VoIP
VoIP Protocols
SCCP, SIP
Voice Codecs
Quality of Service
IEEE 802.1Q (VLAN), IEEE 802.1p
IP Address Assignment
DHCP, static
Security
128 bit AES
Power Over Ethernet (PoE) Support
Network Protocols
TFTP
Network Ports Qty
Voice Features
Echo cancellation (ECN)
Network Features
Class 2 PoE
Display
Display Location
Base
Diagonal Size
5"
Display Resolution
320 x 222 pixels
Display Information
Date, time
Headset jack
Hearing Aid Compatible
Placing / Mounting
Wall-mountable, table-top
Dimensions & Weight (Base)
26.7 cm
15.2 cm
20.3 cm
1.6 kg
74VJ C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £13.65
