Cisco Unified IP Phone 6901
Quicklinx: 96VHWS00 Mfr#: CP-6901-C-K9=
Type: VoIP phone
Handsets Included: 1
Answer Machine: [N/A]
Nuisance Call Blocker: No
Mounting: Table-top, Wall-mountable
Hurry, only 2 left in stock!
£94.64 ex VAT
£113.56 inc VAT
The Cisco Unified IP Phone 6901 is a single-line endpoint delivering cost-effective access to Cisco unified communications. Designed with a trim line-like low profile, the Cisco Unified IP Phone 6901 is an ideal solution for lobbies, hallways, elevators, hotel bathrooms, or other settings that have an occasional need for voice communications services.
The Cisco Unified IP Phone 6901 supports two incoming calls with call-waiting service. Fixed feature keys provide one-touch access to hold, redial, and call waiting. Transfer and conference can be supported by using the hook switch similar to that of traditional analog phones.
The Cisco Unified IP Phone 6901 is an earth-friendly solution. As with the other Cisco Unified IP Phone 6900 Series endpoints, the Cisco Unified IP Phone 6901 takes advantage of reground and recyclable plastics for a more earth responsible solution.
  • Desk and wall mountable
    A foldable footstand makes viewing of and use of the buttons and keys easy in the desk-mount case.
  • Co-branding
    You can include your logo on the Cisco Unified IP Phones 6900 series endpoints. Cisco has approved third-party vendors to produce the labels. One small paper label is inserted under the plastic cover at the co-branding area and shipped together with the phone from the factory.
  • Voice quality
    Comfort-noise generation and voice-activity-detection (VAD) programming is supported on a system basis.
  • Volume control
    A volume-control toggle makes volume adjustments easy for the handset, monitor speaker, and ringer.
  • Call-control compatibility
    The phones are supported on Cisco unified communications manager and Cisco unified communications manager business edition versions 7.1.3 and later, as well as Cisco unified communications manager Express 8.0 and later using SCCP.
Cisco Unified IP Phone 6901 Standard - VoIP phone
VoIP phone
VoIP Protocols
SCCP
Voice Codecs
G.729a, G.729ab, G.711u, G.711a
Speakerphone
Yes (digital duplex)
Voice Mail Capability
Call Services
Voice Mail, Call Waiting, Call Forwarding, Call Transfer, Call Hold
Network Ports Qty
1 x Ethernet 10/100Base-TX
Body Colour
Charcoal
1-year warranty
VoIP phone
Body Colour
Charcoal
Body Material
ABS plastic
Phone Features
Call Services
Dialer Type
Keypad
Dialer Location
Base
Conference Call Capability
Speakerphone
Function Buttons
Hold button, auto redial button
Volume Control
Ringer Control
Indicators
Voice message waiting indicator
Additional Features
Music on hold, built-in web server
IP Telephony
VoIP
VoIP Protocols
SCCP
Voice Codecs
IP Address Assignment
DHCP, static
Power Over Ethernet (PoE) Support
Network Protocols
Cisco Discovery Protocol (CDP)
Network Ports Qty
Voice Features
Comfort noise generation (CNG), voice activity detection (VAD)
RAM
32 MB
Hearing Aid Compatible
Placing / Mounting
Wall-mountable, table-top
Also Included
8 MB
VCCI Class B ITE, CISPR 22 Class B, CISPR 24, EN 60950, EN 61000-3-2, IEC 60950, EN 61000-3-3, EN55024, UL 60950, EN50082-1, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, ACA TS001, AS/NZS 60950-1, CSA C22.2 No. 60950-00, FCC CFR47 Part 68, FCC CFR47 Part 15 B
Dimensions & Weight (Base)
9.4 cm
4.6 cm
20.5 cm
655 g
Limited warranty - 1 year
96VH C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £13.93
Type: VoIP phone
Mounting: Table-top
Mounting: Wall-mountable
Big Button: No
Brand: Cisco
