The Cisco Unified IP Phone 6901 is a single-line endpoint delivering cost-effective access to Cisco unified communications. Designed with a trim line-like low profile, the Cisco Unified IP Phone 6901 is an ideal solution for lobbies, hallways, elevators, hotel bathrooms, or other settings that have an occasional need for voice communications services.
The Cisco Unified IP Phone 6901 supports two incoming calls with call-waiting service. Fixed feature keys provide one-touch access to hold, redial, and call waiting. Transfer and conference can be supported by using the hook switch similar to that of traditional analog phones.
The Cisco Unified IP Phone 6901 is an earth-friendly solution. As with the other Cisco Unified IP Phone 6900 Series endpoints, the Cisco Unified IP Phone 6901 takes advantage of reground and recyclable plastics for a more earth responsible solution.
Desk and wall mountable
A foldable footstand makes viewing of and use of the buttons and keys easy in the desk-mount case. -
Co-branding
You can include your logo on the Cisco Unified IP Phones 6900 series endpoints. Cisco has approved third-party vendors to produce the labels. One small paper label is inserted under the plastic cover at the co-branding area and shipped together with the phone from the factory. -
Voice quality
Comfort-noise generation and voice-activity-detection (VAD) programming is supported on a system basis. -
Volume control
A volume-control toggle makes volume adjustments easy for the handset, monitor speaker, and ringer. -
Call-control compatibility
The phones are supported on Cisco unified communications manager and Cisco unified communications manager business edition versions 7.1.3 and later, as well as Cisco unified communications manager Express 8.0 and later using SCCP.
- Cisco Unified IP Phone 6901 Standard - VoIP phone
- Product Type
- VoIP phone
- VoIP Protocols
- SCCP
- Voice Codecs
- G.729a, G.729ab, G.711u, G.711a
- Speakerphone
- Yes (digital duplex)
- Voice Mail Capability
- Call Services
- Voice Mail, Call Waiting, Call Forwarding, Call Transfer, Call Hold
- Network Ports Qty
- 1 x Ethernet 10/100Base-TX
- Body Colour
- Charcoal
- 1-year warranty
- Product Type
- VoIP phone
- Body Colour
- Charcoal
- Body Material
- ABS plastic
Phone Features
- Call Services
- Dialer Type
- Keypad
- Dialer Location
- Base
- Conference Call Capability
- Speakerphone
- Function Buttons
- Hold button, auto redial button
- Volume Control
- Ringer Control
- Indicators
- Voice message waiting indicator
- Additional Features
- Music on hold, built-in web server
IP Telephony
- VoIP
- VoIP Protocols
- SCCP
- Voice Codecs
- IP Address Assignment
- DHCP, static
- Power Over Ethernet (PoE) Support
- Network Protocols
- Cisco Discovery Protocol (CDP)
- Network Ports Qty
- Voice Features
- Comfort noise generation (CNG), voice activity detection (VAD)
- RAM
- 32 MB
- Hearing Aid Compatible
- Placing / Mounting
- Wall-mountable, table-top
- Also Included
- 8 MB
- VCCI Class B ITE, CISPR 22 Class B, CISPR 24, EN 60950, EN 61000-3-2, IEC 60950, EN 61000-3-3, EN55024, UL 60950, EN50082-1, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, ACA TS001, AS/NZS 60950-1, CSA C22.2 No. 60950-00, FCC CFR47 Part 68, FCC CFR47 Part 15 B
Dimensions & Weight (Base)
- 9.4 cm
- 4.6 cm
- 20.5 cm
- 655 g
- Limited warranty - 1 year
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.68 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £9.87 |
