Cisco UCS SmartPlay Select C240 M4 Standard Intel Xeon E5-2630v3(x2) 128GB (8x16GB)
Quicklinx: BDMFWS00 Mfr#: UCS-SPL-C240M4-S1
  • Xeon
Delivering performance, versatility, and density without compromise, the Cisco UCS B200 M3 Blade Server addresses a broad set of workloads, from IT and web infrastructure to distributed database. The Cisco UCS B200 M3 Server harnesses the power of the fast processor, two hard drives, and up to 8 x 10GE to deliver exceptional levels of performance, memory expandability, and I/O throughput for most applications. In addition, Cisco UCS has the architectural advantage of not having to power and cool switches in each blade chassis. Having a large power budget available for blades enables Cisco to design uncompromised expandability and capabilities in its blade servers, which results in outstanding performance.
Cisco UCS SmartPlay Select C240 M4 Standard 1 - rack-mountable - Xeon E5-2630V3 2.4 GHz - 128 GB - no HDD
Server - rack-mountable
Height (Rack Units)
2U
Server Scalability
2-way
2 x Intel Xeon E5-2630V3 / 2.4 GHz (, up to 3.2 GHz, (8-core)
Processor Socket
LGA2011-v3 Socket
Cache Memory
40 MB
Cache Per Processor
20 MB
RAM
128 GB (installed) / 384 GB (max) - DDR4 SDRAM - ECC - PC4-17000
Storage Controller
RAID (SATA 6Gb/s / SAS 12Gb/s) - PCIe 3.0
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
No optical drive
Graphics Controller
Matrox G200e
Video Memory
8 MB
GigE, 10 GigE, 10Gb FCoE
Power Redundancy
OS Provided
No operating system
Software Included
Cisco ONE Foundation
44.8 cm x 73.8 cm x 8.7 cm
Limited warranty - replacement - 3 years - response time: next business day
Server
Product Form Factor
Rack-mountable - 2U
Built-in Devices
Backplane
Server Scalability
2-way
Hot-Swap Bays Qty
24
Processor / Chipset
CPU
Clock Speed
2.4 GHz
Max Turbo Speed
3.2 GHz
Number of Cores
8-core
CPU Qty
2
Max CPU Qty
2
CPU Upgradability
Upgradable
CPU Socket
LGA2011-v3 Socket
Chipset Type
Intel C612
Cache Memory
Installed Size
40 MB
Cache Per Processor
20 MB
RAM
Installed Size
128 GB / 384 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
24 (Total) / 16 (empty)
Registered, dual rank
Configuration Features
8 x 16 GB
RAM Supported
PC4-17000 - 384 GB registered - ECC , PC4-17000 - 768 GB Load-Reduced - ECC
Hard Drive
No HDD
Storage Controller
RAID - PCIe 3.0
Controller Interface Type
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60
Buffer Size
2 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Matrox G200e
Video Memory
8 MB
Video Interfaces
VGA
Ethernet Ports
2 x Gigabit Ethernet, 2 x SFP+
Ethernet Controller
Cisco UCS Virtual Interface Card 1227, Intel I350
Ethernet, Fast Ethernet, Gigabit Ethernet, 10 Gigabit Ethernet, 10Gb Fibre Channel over Ethernet (FCoE)
Remote Management Controller
Cisco Integrated Management Controller
PXE support
IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ae, IEEE 802.1Qbb, IEEE 802.1Qaz
Bays
24 (total) / 24 (free) x hot-swap 2.5" SFF
Slots
2 (total) / 0 (free) x CPU , 24 (total) / 16 (free) x DIMM 288-pin , 1 (total) / 1 (free) x PCIe 3.0 x24 - three-quarter-length, full-height (x8 mode) , 1 (total) / 1 (free) x PCIe 3.0 x24 - full-length, full-height (x16 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height (x8 mode) , 2 SD card (internal)
2 x USB 3.0 , 1 x VGA , 1 x serial - RJ-45 , 2 x LAN (Gigabit Ethernet) - RJ-45 , 1 x management (NIC) - RJ-45 , 1 x KVM (1 in front) , 2 x LAN (10Gigabit Ethernet) (SFP+)
SAS expander, 2 x CPU Heatsink, rack rail kit, riser card, 24 x HDD filler panel
Video / USB / serial cable
CISPR 22 Class A, BSMI CNS 13438 Class A, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class A, AS/NZS 60950-1, ICES-003 Class A, UL 60950-1, UL 60950-1 Second Edition, Directive 2004/108/EC, CSA C22.2 No. 60950-1 Second Edition, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, Directive 2006/95/EC, KN24, KN22 Class A, GB4943.1-2001, EN 300386
Power supply - hot-plug
Power Redundancy
Power Redundancy Scheme
1+1
Installed Qty
2
Max Supported Qty
2
Power Provided
1400 Watt
Operating System / Software
OS Provided
No operating system
Software
44.8 cm
73.8 cm
8.7 cm
5 °C
35 °C
10 - 90% (non-condensing)
