Cisco UCS C-Series Rack-Mount Servers extend unified computing innovations to an industry-standard form factor to help reduce total cost of ownership (TCO) and increase business agility. Designed to operate both in standalone environments and as part of the Cisco Unified Computing System, the series employs Cisco technology to help customers handle the most challenging workloads. The series incorporates a standards-based unified network fabric, Cisco VN-Link virtualization support, and Cisco Extended Memory Technology. It supports an incremental deployment model and protects customer investments with a future migration path to unified computing.
The Cisco UCS C200 M2 High-Density Rack-Mount Server is a high-density server with balanced compute performance and I/O flexibility. This price-to-performance optimized two-socket, one-rack-unit (1RU) rack-mount server is designed to balance simplicity, performance, and density for web infrastructure and mainstream data center, small-office, and remote-office applications. Its single-rack-unit size makes it useful for service providers offering dedicated or multi-tenant hosting, and its economical price makes it well suited to the appliance market.
- Cisco UCS C200 M2 High-Density Rack-Mount Server - rack-mountable Xeon X5650 2.66 GHz - 8 GB - no HDD
- Server - rack-mountable
- Height (Rack Units)
- 1U
- Processor
- 2 x Intel Xeon X5650 / 2.66 GHz (up to 3.06 GHz, (6-core)
- Processor Socket
- LGA1366 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Execute Disable Bit, Enhanced Intel SpeedStep Technology, Intel Virtualization Technology, Intel Turbo Boost Technology
- Cache Memory
- 24 MB L3 Cache
- Cache Per Processor
- 12 MB
- RAM
- 8 GB (installed) / 96 GB (max) - DDR3 SDRAM - Advanced ECC - PC3-10600
- Storage Controller
- RAID (SATA 3Gb/s)
- Server Storage Bays
- Hot-swap 3.5"
- Hard Drive
- No HDD
- Optical Storage
- DVD-Writer
- Graphics Controller
- Matrox MGA G200
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- 42.9 cm x 70.6 cm x 4.3 cm
- Server
- Product Form Factor
- Rack-mountable - 1U
- Front Accessible Bays Qty
- 1
- Hot-Swap Bays Qty
- 4
Processor / Chipset
- CPU
- Intel Xeon X5650
- Clock Speed
- 2.66 GHz
- Max Turbo Speed
- 3.06 GHz
- Number of Cores
- 6-core
- 64-bit Computing
- CPU Qty
- 2
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1366 Socket
Cache Memory
- Installed Size
- L3 Cache - 24 MB
- 12 MB
RAM
- Installed Size
- Technology
- Effective Memory Speed
- 1333 MHz
- Rated Memory Speed
- 1333 MHz
- Memory Specification Compliance
- PC3-10600
- Registered, Memory Mirroring
- Configuration Features
- 2 x 4 GB
Hard Drive
- No HDD
Storage Controller
- RAID - integrated
- Controller Interface Type
- SATA 3Gb/s
- RAID Level
- RAID 0, RAID 1
Optical Storage
- DVD±RW DVD-Writer
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Matrox MGA G200
- Video Interfaces
- VGA
- Integrated
- Ethernet Ports
- 2 x Gigabit Ethernet
- Data Link Protocol
- Remote Management Protocol
- IPMI 2.0
- Bays
- 4 (total) / 4 (free) x hot-swap 3.5" , 1 (total) / 0 (free) x external
- Slots
- 2 (total) / 0 (free) x CPU , 12 (total) / 10 (free) x memory , 1 (total) / 1 (free) x PCIe 2.0 x8 - half-length, low-profile , 1 (total) / 1 (free) x PCIe 2.0 x16 - half-length, full-height
- 1 x serial , 4 x USB 2.0 (2 front, 2 rear) , 1 x management (NIC) , 1 x VGA , 2 x LAN (Gigabit Ethernet) , 1 x serial - console
- CISPR 22 Class A, GOST, CISPR 24, EN 61000-3-2, SABS, VCCI Class A ITE, EN 61000-3-3, EN55024, EN55022 Class A, CSA 22.2 No. 60950, CB, AS/NZS 60950-1, CCC, ICES-003 Class A, IRAM, UL 60950-1, EN 60950-1
- Power supply
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Installed Qty
- 1
- Max Supported Qty
- 2
- Voltage Required
- Power Provided
- 650 Watt
- 42.9 cm
- 70.6 cm
- 4.3 cm
- 10 °C
- 35 °C
- 5 - 93% (non-condensing)
