Cisco UC Phone 6945 Charcoal Standard Handset
Quicklinx: 7PVPWS00 Mfr#: CP-6945-C-K9=
The Cisco Unified IP Phone 6945 is an innovative IP endpoint that delivers affordable, business-grade voice communication and support for video communications services to customers worldwide.
This Gigabit Ethernet enhanced business IP phone supports wideband audio handset and headset communications to provide clear voice quality in a business environment. The phone also supports Power-over-Ethernet (PoE) Class 1, which is the low-power consumption IP phone to save energy and support your green initiatives.
  • Gigabit Ethernet switch
    The phone has a 10/100/1000BASE-T Ethernet connection through two RJ-45 ports, one for the LAN connection and the other for connecting a downstream Ethernet device such as a PC.
  • PoE Class 1
    It supports IEEE 802.3af PoE (Class 1); power consumption does not exceed 3.84 watts.
  • Lighted hold key
    The key lights, when pressed, to put a call on hold, and stays lit until the held call resumes. The key flashes if one call is held while another is engaged. The key is dark when no calls are on hold.
  • Lighted menu key
    The key lights, when pressed, to access voicemail messages, call logs, network settings, user preferences, corporate directories, and XML services; it stays lit while menu items are active.
  • Lighted message waiting indicator (MWI)
    The key lights when there is new voicemail, and the light is visible on both the phone chassis and the handset; it stays lit until you process your new voicemail.
  • Deep-sleep option
    You can save power by cycling power - by time of day and day of week.
  • Co-branding
    The Co-branding button allows you to include your logo on the Cisco Unified IP Phones 6900 Series phones. Cisco has approved third-party vendors to produce the buttons.
  • Graphical display
    A white backlit, monochrome, 396 x 162 pixel-based display with an antiglare screen provides scrollable access to calling features and text-based XML applications.
  • Four soft-key buttons and a scroll toggle bar
    Your calling options are dynamically presented; the scroll toggle bar allows easy movement through the displayed information.
  • Network features
    Network features include Cisco discovery protocol and IEEE 802.1 p/q tagging and switching.
  • Volume control
    A volume-control toggle provides easy decibel-level adjustments of the handset, monitor speaker, and ringer.
  • Dual-position foot stand
    The display is easy to view and the buttons and keys are easy to use; you can remove the foot stand for wall mounting, with mounting holes located on the base of the phone.
  • Multiple ring tones
    The phone offers seven user-adjustable ring tones.
  • American Disabilities Act (ADA) features
    The hearing-aid-compatible (HAC) handset meets the requirements set by the ADA; it also meets ADA HAC requirements for a magnetic coupling to approved hearing aids. The phone dialing pad also complies with ADA standards.
  • Voice quality
    Comfort-noise generation and voice-activity-detection (VAD) programming is provided on a system basis.
Cisco Unified IP Phone 6945 Standard - VoIP phone
VoIP phone
Main Features
Multiple VoIP protocol support, integrated Ethernet switch
VoIP Protocols
SCCP, SIP, SRTP
Voice Codecs
G.711, G.722, G.729a, G.729ab, G.711a, iLBC, G.729b
Lines Supported
Multiline
Speakerphone
Yes (digital duplex)
Caller ID
Voice Mail Capability
Call Services
Voice Mail, Caller ID, Call Transfer, Call Hold
Display
LCD display - monochrome - Yes
Display Features
Anti-glare
Network Ports Qty
2 x Ethernet 10Base-T/100Base-TX/1000Base-T
Compatible Software
Cisco Unified Communications Manager 7.1 or later, Cisco Unified Communications Manager Business Edition 7.1(2)
Body Colour
Charcoal
1-year warranty
VoIP phone
Body Colour
Charcoal
Body Material
ABS plastic
Phone Features
Call Services
Dialer Type
Keypad
Dialer Location
Base
Conference Call Capability
Speakerphone
Menu Operation
Function Buttons
Conference button, transfer button, hold button
Volume Control
Ringer Control
Ring Tones
7
Indicators
Voice message waiting indicator, hold indicator
Firmware Upgradable
IP Telephony
Main Features
VoIP
VoIP Protocols
SCCP, SIP, SRTP
Voice Codecs
Lines Supported
Multiline
Quality of Service
IEEE 802.1Q (VLAN), IEEE 802.1p
Power Over Ethernet (PoE) Support
Network Protocols
TFTP, Cisco Discovery Protocol (CDP), SRTP
Network Ports Qty
Compatible Software
Voice Features
Comfort noise generation (CNG), voice activity detection (VAD)
Display
Display Location
Base
Display Resolution
396 x 162 pixels
Backlit
Display Languages
Danish, Hebrew, Hungarian, Czech, Croatian, Slovenian, Thai, Slovak, Brazilian Portuguese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Latvian, Lithuanian, Estonian, Serbian, Romanian, Catalan, Japanese, Chinese, Korean
Anti-glare
Headset jack / RJ-9
Hearing Aid Compatible
Placing / Mounting
Wall-mountable, table-top
Power adapter
VCCI Class B ITE, CISPR 22 Class B, CISPR 24, EN 60950, EN 61000-3-2, EN55022, IEC 60950, EN 61000-3-3, UL 60950, EN50082-1, CSA 22.2 No. 60950, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, ACA TS001, ADA, FCC CFR47 Part 68, FCC CFR47 Part 15 B, AS/NZS 3548 Class B, AS/NZS 60950
Power adapter - external
Dimensions & Weight (Base)
18.8 cm
20.5 cm
16.4 cm
1.102 kg
Limited warranty - 1 year
