The Cisco TelePresence SX20 Quick Set (SX20 Quick Set) can transform any flat panel display into a sleek and powerful telepresence system. The SX20 Quick Set is designed to deliver high definition video and multiparty conferencing with the flexibility to accommodate various room size and configurations - all at a value price. The SX20 Quick Set supports embedded capability for multipoint support with Cisco TelePresence MultiSite technology, enabling users to add three additional participants to a telepresence call.
SX20 Quick Set combines a powerful codec, three camera choices, and a dual-display option in an easy-to-deploy and easy-to-use solution. Whether you're a small business just getting started with telepresence or a large enterprise looking to expand your existing deployment, the SX20 Quick Set delivers the performance you would expect from more expensive systems - in a compact and feature-rich package. Cisco TelePresence SX20 Quick Set is designed to truly extend the power of in-person to everyone, everywhere.
Seamless connectivity
With dual HDMI and DVI inputs, alongside Ethernet 10Base-T/100Base-TX/1000Base-T support, the Cisco TelePresence System SX20 ensures a wide range of connectivity options for various devices and networks, facilitating effortless integration into existing setups. -
High-definition video
Equipped with a Precision HD 1080p 12x Camera and supporting resolutions up to 1920 x 1080, this video conferencing kit delivers crisp, clear, and vibrant video quality, making remote communications more effective and engaging. -
Versatile audio inputs
Featuring multiple audio inputs, including external microphones and a wireless remote control, the system offers flexible audio solutions to meet the demands of dynamic conferencing environments. -
Robust environmental adaptability
Designed to operate within a broad range of temperatures from 0°C to 35°C, the Cisco TelePresence System SX20 Quick Set is built to perform reliably in diverse environmental conditions, ensuring uninterrupted operation. -
Comprehensive standards compliance
Adhering to stringent standards such as CSA C22.2 No. 60950-1-07, EN 60950-1, and FCC Part 15 B, this system meets high safety, reliability, and quality benchmarks, providing peace of mind in its deployment and use.
- Cisco TelePresence System SX20 Quick Set with Precision HD 1080p 12x Camera - video conferencing kit
- Video conferencing kit
- Digital Signaling Protocol
- H.323, SIP
- Data Compression Protocol
- G.711, G.722, H.263, H.264, H.263+, G.722.1
- Video Input
- Digital video camera - HD-SDI output, HDMI output
- Video Output
- Codec board
- Audio Input
- Microphone
- Input Device
- Remote control (wireless)
- Networking
- Network adapter - Ethernet, Fast Ethernet, Gigabit Ethernet
- Power
- AC 120/230 V (50/60 Hz)
- 90 days warranty
- Dimensions & Weight Details
- Main system - Width 30 cm Depth 18 cm Height 3.4 cm Weight 1.4 kg
Modem
- H.323, SIP
Video Input
- Digital video camera (colour) - external
- Interface Type
- Digital Video Capture Resolution
- 1280 x 720, 1920 x 1080
Video Output
- Codec board - external
- Supported Display Graphics
- VGA (640x480), XGA (1024x768), SVGA (800x600), HDTV (1920x1080), HD (1280 x 720), 1280x768, 1024x576, 704x576
- Digital Video Standard
- High-Definition Multimedia Interface (HDMI)
Audio Input
- Microphone - external
Input Device
- Remote control
- Connectivity Technology
- Wireless
- Network adapter
- Wired
- Data Link Protocol
- TCP/IP, NTP, DHCP, DNS
- 2 x display / video - HDMI output - 19 pin HDMI Type A , 2 x microphone - input - mini-phone 3.5 mm 4-pole , 1 x audio - input - mini-phone 3.5 mm , 1 x display / video - input - DVI , 1 x display / video - input - 19 pin HDMI Type A , 1 x network - Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45 , 2 x USB
- EN55022 Class B, FCC Part 15 B, EN 60950-1, CSA C22.2 No. 60950-1-07
- Power Device
- Power supply
- Voltage Required
- 40 Watt
- Software Included
- Cisco Collaboration Endpoint 8
- Limited warranty - 90 days
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
