Cisco TelePresence SX20 Quick Set Precision 40 Camera
Quicklinx: CN7KWS00 Mfr#: CTS-SX20N-P40-K9
The Cisco TelePresence SX20 Quick Set (SX20 Quick Set) can transform any flat panel display into a sleek and powerful video conferencing system. The SX20 Quick Set is designed to deliver high definition video and multiparty conferencing with the flexibility to accommodate various room size and configurations - all at a value price.
SX20 Quick Set combines a powerful codec, premium resolution of 1080p, and a dual-display feature in an easy-to-deploy and easy-to-use solution. Whether you're a small business just getting started with telepresence or a large enterprise looking to expand your existing deployment, the SX20 Quick Set delivers the performance you would expect from more expensive systems - in a compact, feature-rich and affordable package. Cisco TelePresence SX20 Quick Set is designed to truly extend the power of in-person to everyone, everywhere.
  • Seamless connectivity
    With dual HDMI output and input, alongside DVI, Ethernet, and multiple audio interfaces, the Cisco TelePresence System SX20N Quick Set ensures a wide range of connectivity options for various setups and configurations.
  • High-quality video
    Equipped with the Precision 40 Camera, this system captures and delivers video in stunning resolutions up to Full HD 1080p, supported by a codec board that handles a variety of display graphics from VGA to HDTV 1080p.
  • Superior audio input
    Features an external microphone form factor with a wireless remote control, enhancing audio input quality and allowing for effortless control over the conference environment.
  • Robust environmental adaptability
    Designed to operate within a broad range of temperatures from 0°C to 35°C and humidity levels from 10 - 90% (non-condensing), ensuring reliable performance in diverse operating conditions.
  • Comprehensive standards compliance
    Meets a variety of compliance standards including CSA C22.2 No. 60950-1-07, EN 60950-1, EN55022 Class B, and FCC Part 15 B, affirming its safety and quality for global markets.
Cisco TelePresence System SX20N Quick Set with Precision 40 Camera - video conferencing kit
Video conferencing kit
Digital Signaling Protocol
H.323, SIP
Data Compression Protocol
G.711, G.722, H.263, H.264, H.263+, G.722.1
Video Input
Digital video camera - HDMI output
Video Output
Codec board
Audio Input
Microphone
Input Device
Remote control (wireless)
Network adapter - Ethernet, Fast Ethernet, Gigabit Ethernet
90 days warranty
Dimensions & Weight Details
Main system - Width 30 cm Depth 18 cm Height 3.4 cm Weight 1.4 kg
Modem
H.323, SIP
Video Input
Digital video camera (colour) - external
Interface Type
HDMI output
Digital Video Capture Resolution
1280 x 720, 1920 x 1080
Video Output
Codec board - external
Supported Display Graphics
VGA (640x480), XGA (1024x768), SVGA (800x600), HDTV (1920x1080), HD (1280 x 720), 1280x768, 1024x576, 704x576
Digital Video Standard
High-Definition Multimedia Interface (HDMI)
Audio Input
Microphone - external
Input Device
Remote control
Wireless
Network adapter
Wired
Network / Transport Protocol
TCP/IP, NTP, DHCP, DNS
2 x display / video - HDMI output - 19 pin HDMI Type A , 2 x microphone - input - mini-phone 3.5 mm 4-pole , 1 x audio - input - mini-phone 3.5 mm , 1 x display / video - input - DVI , 1 x display / video - input - 19 pin HDMI Type A , 1 x network - Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45 , 2 x USB
EN55022 Class B, FCC Part 15 B, EN 60950-1, CSA C22.2 No. 60950-1-07
Power supply
40 watt
Software Included
Cisco Collaboration Endpoint 8
Limited warranty - 90 days
35 °C
