Video-Enable Your Small Collaboration Spaces - the Cisco TelePresence SX10 Quick Set is an all-in-one unit that combines with any flat-panel display to video-enable your small collaboration spaces. It offers tremendous affordability for small- to medium-sized businesses just starting out with telepresence, or in extending telepresence throughout an enterprise.
Seamless connectivity
With integrated support for Ethernet 10Base-T/100Base-TX (PoE), HDMI input and output, and wireless remote control, this device ensures a smooth and efficient setup for any meeting room. -
High-quality audio and video
Features like echo cancellation, auto gain control, and a built-in camera and microphone deliver a superior audio and video conferencing experience, capturing Full HD 1080p video and clear sound. -
Versatile performance
Supports a wide range of video codecs including H.263, H.263+, and H.264, and voice codecs like G.711 and G.722, ensuring compatibility and peak performance in various network environments.
- Cisco TelePresence SX10 HD - video conferencing device
- Video conferencing device
- VoIP Protocols
- SIP
- Codec
- H.263, H.263+, H.264, G.711, G.722, G.729, G.729ab, G.711a, G.722.1
- 27.5 cm x 9.1 cm x 11.7 cm
- 900 g
- Max Transfer Rate
- 3 Mbps
- Digital Signaling Protocol
- SIP
- Data Compression Protocol
- G.729, G.711, G.722, H.263, H.264, G.729AB, H.263+, G.722.1, H.350
- Auto gain control, echo cancellation
- Video Input
- Digital video camera
- Video Output
- Codec board - 1920 x 1080
- Audio Input
- Microphone
- Input Device
- Remote control (wireless)
- Networking
- Network adapter - Ethernet, Fast Ethernet
- Power
- AC 120/230 V (50/60 Hz)
- VoIP Protocols
- SIP
- Voice Codecs
- G.711, G.722, G.729, G.729ab, G.711a, G.722.1
- Video Codecs
- Quality of Service
- IEEE 802.1Q (VLAN), Differentiated Services (DiffServ), IEEE 802.1p
- Network Protocols
- HTTP, HTTPS
- 27.5 cm
- 9.1 cm
- 11.7 cm
- 900 g
- Built-in Devices
- Microphone, camera
Modem
- Max Transfer Rate
- 3 Mbps
- SIP
Video Input
- Digital video camera (colour) - integrated
- Digital Video Capture Resolution
- 1920 x 1080
Video Output
- Codec board
- Max External Resolution
- 1920 x 1080
- Supported Display Graphics
- VGA (640x480), XGA (1024x768), SVGA (800x600), HDTV (1920x1080), 1152x864, HD (1280 x 720), 720x480, 1280x768, 848x480, 704x576
- Digital Video Standard
- High-Definition Multimedia Interface (HDMI)
Audio Input
- Microphone - integrated
Input Device
- Remote control
- Connectivity Technology
- Wireless
- Network adapter
- Wired
- Data Link Protocol
- TCP/IP, NTP, DHCP, DNS
- Flow control, power over Ethernet (PoE), LDAP support, VLAN support, DiffServ support, IPv6 support, Quality of Service (QoS), SSH support, IPv4 support, Class of Service (CoS), Secure Copy (SCP)
- IEEE 802.1Q, IEEE 802.1p, IEEE 802.1x
- 1 x network - Ethernet 10Base-T/100Base-TX (PoE) - RJ-45 , 1 x USB , 1 x audio / video - HDMI input - 19 pin HDMI Type A , 1 x video - 15 pin HD D-Sub (HD-15) , 1 x audio / video - HDMI output - 19 pin HDMI Type A , 1 x microphone - input - mini-phone 3.5 mm 4-pole , 1 x audio - line-out - mini-phone stereo 3.5 mm
- Cables Included
- 1 x HDMI cable , 1 x network cable
- Mounting Kit
- Included
- EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, FCC CFR47 Part 15, UL 60950-1, EN 60950-1, CSA C22.2 No. 60950-1-07, Directive 2004/108/EC, Directive 2006/95/EC, IEC60950-1
- Power Device
- Power supply - internal
- Voltage Required
- 12 watt
- 0 °C
- 40 °C
- 10 - 90%
