Cisco StackWise Plus Stacking Cable 50cm
Quicklinx: C31TWS00 Mfr#: CAB-STK-E-0.5M=
Cisco is the worldwide leader in networking for the Internet. Cisco provides the broadest line of solutions for transporting data, voice and video within buildings, across campuses, or around the world. Cisco solutions ensure that networks both public and private operate with maximum performance, security, and flexibility.
  • Enhanced connectivity
    The Cisco StackWise Plus model includes a stacking cable that significantly improves the connectivity between network switches, allowing for a more integrated and efficient network infrastructure
  • PC compatibility
    Designed with PC compatibility in mind, this product ensures seamless integration into existing network setups, making it a versatile choice for a wide range of applications
Cisco StackWise Plus - stacking cable
Stacking cable
Cable Length
50 cm
Catalyst 2960, 2960-24, 2960-48, 2960G-24, 2960G-48, 2960S-24, 2960S-48, Switch Module 3110
Network Cable Type
Stacking cable
Cable Length
50 cm
Cisco Catalyst 2960-24LC-S, 2960-24LT-L, 2960-24PC-L, 2960-24PC-S, 2960-24-S, 2960-24TC, 2960-24TC-L, 2960-24TC-S, 2960-24TT, 2960-48PST-L, 2960-48PST-S, 2960-48T, 2960-48TC, 2960-48TC-L, 2960-48TC-S, 2960-48TT, 2960-48TT-L, 2960-48TT-S, 2960-8TC, 2960-8TC-S, 2960G-24TC, 2960G-48TC, 2960G-8TC, 2960PD-8TT-L, 2960S-24PD-L, 2960S-24PS-L, 2960S-24TD-L, 2960S-24TS-L, 2960S-24TS-S, 2960S-48FPD-L, 2960S-48FPS-L, 2960S-48LPD-L, 2960S-48LPS-L, 2960S-48TD-L, 2960S-48TS-L, 2960S-48TS-S, Switch Module 3110G for IBM BladeCenter, Switch Module 3110X for IBM BladeCenter
