Cisco Small Business 220 series smart plus switches bridge the gap between managed and smart switches to offer customers the best of both worlds. Combining powerful performance with reliability, they provide the higher levels of security, management, and scalability you expect from managed switches, affordably priced like smart switches.
ETHERNET PORT CONFIGURATION
48-port 10/100M, 2 x 1G combo SFP -
POWER OVER ETHERNET
48 PoE ports with 375W total power budget -
CONFIGURATION & CONTROL
Easy-to-use GUI interface and CLI offers basic capabilities to configure, secure, and monitor your network -
KEY FEATURES
VLANs, QoS, Link Aggregation, Port Mirroring, Spanning Tree, IGMP Snooping, Access Control List (ACL), 802.1X / RADIUS, DoS prevention -
PEACE OF MIND
Limited-lifetime warranty, one-year technical support, and free software fixes for the term of the warranty
- Cisco 220 Series SF220-48P - switch - 48 ports - Managed - rack-mountable
- Switch - 48 ports - Managed
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Fast Ethernet
- Ports
- 48 x 10/100 (PoE) + 2 x combo Gigabit SFP
- Power Over Ethernet (PoE)
- PoE
- PoE Budget
- 375 W
- Performance
- Forwarding performance (64-byte packet size): 10.12 Mpps , Switching capacity: 13.6 Gbps
- MAC Address Table Size
- 8192 entries
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, CLI
- Flow control, Layer 2 switching, DHCP support, BOOTP support, VLAN support, IGMP snooping, Syslog support, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Trivial File Transfer Protocol (TFTP) support, Quality of Service (QoS), RADIUS support, MLD snooping, reset button, LLDP support, Link Aggregation Control Protocol (LACP)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
- Power
- AC 120/230 V (50/60 Hz)
- 44 cm x 35 cm x 4.4 cm
- 5.12 kg
- Localisation
- United Kingdom
- Limited lifetime warranty
- Enclosure Type
- Desktop, rack-mountable 1U
- Subtype
- Fast Ethernet
- Ports
- PoE
- PoE Budget
- 375 W
- Performance
- 8192 entries
- Authentication Method
- RADIUS, TACACS+
- RAM
- 128 MB
- Flash Memory
- 32 MB
- Status Indicators
- Port transmission speed, system, PoE, link/activity
- 48 x 100Base-TX RJ-45 PoE - 15.4 W , 2 x 1000Base-T RJ-45 , 2 x 1000Base-X SFP
- Power Device
- Internal power supply
- Voltage Required
- MTBF
- 210,753 hours
- C-Tick, UL 60950, FCC CFR47 Part 15, CSA 22.2
- Localisation
- United Kingdom
- 44 cm
- 35 cm
- 4.4 cm
- 5.12 kg
- Limited warranty - replacement - lifetime , Technical support - web support - 1 year , Technical support - phone consulting - 1 year , Limited warranty - power supply and fans - 1 year , Limited warranty - software - 90 days
- 0 °C
- 50 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
