Today Wi-Fi is the primary way for mobile access; small to medium-sized businesses are looking for simple, yet easy-to-deploy Wi-Fi networks where they can provide excellent experience to their employees and customers. To stay productive, they need dependable, business-class access to network applications throughout the office. The Cisco WAP581 Wireless-AC Dual Radio Wave 2 Access Point with 2.5GbE LAN provides a simple, cost-effective way to extend highly secure, high-performance mobile networking to your employees and guests, so they can stay connected anywhere in the office, regardless of what mobile devices they use. The Cisco WAP581 Wireless-AC Dual Radio Wave 2 Access Point with 2.5GbE LAN uses concurrent dual-band radio for improved coverage and user capacity. The 4 x 4 MU-MIMO technology on the 5 GHz radio and 3 x 3 MIMO on the 2.4 GHz radio allow the access point to run at maximum performance and deliver better user experience. Two Gigabit Ethernet LAN interfaces, one with 2.5 Gigabit Ethernet and the second with 1 Gigabit Ethernet with PoE facilitate flexible installation and reduce cabling and wiring costs. Intelligent quality-of-service (QoS) features let you prioritize bandwidth-sensitive traffic for voice-over-IP (VoIP) and video applications. To provide highly secure guest access to visitors and other users, Cisco WAP581 Wireless-AC Dual Radio Wave 2 Access Point with 2.5GbE LAN supports a captive portal with multiple authentication options and the ability to configure rights, roles, and bandwidth. A customized guest login page lets you present a welcome message and access details, and reinforces your brand with company logos.
CONNECTIVITY
Provides cost-effective 802.11ac Wave 2 connectivity with speeds up to 2.8 Gbps and uses a concurrent dual-band radio for improved coverage and user capacity -
TECHNOLOGY
Supports 4 x 4 multi-user multiple-input, multiple-output (MU-MIMO) technology on a 5.0-GHz radio and 3 x 3 MIMO technology on a 2.4-GHz radio for maximum performance -
POWER OVER ETHERNET
Dual Gigabit Ethernet (2.5 G and 1 G) LAN with PoE support, and link aggregation -
GUEST WIFI
Provides secure guest access with multiple authentication options; supports social media login such as Google and Facebook -
PROTECTION
Cisco Umbrella integration protects wireless devices from malware and phishing
 - Cisco Small Business WAP581 - radio access point - Wi-Fi 5
 - Radio access point
- Form Factor
 - External
- Localisation
 - Saudi Arabia, South Africa, Vietnam, Hong Kong, Thailand, United Kingdom, Europe, Turkey
- RAM
 - 256 GB
- Flash Memory
 - 128 MB
- Data Link Protocol
 - IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
- Frequency Band
 - 2.4 GHz, 5 GHz
- Capacity
 - VLANs supported: 32 , Connection / user qty: 200 , Concurrent users per radio: 50 , Maximum number of access points (per cluster): 16 , Maximum number of configured SSIDs: 16
- Included Accessories
 - Wall/ceiling mounting kit
- Power Over Ethernet (PoE) Supported
 - PoE+
 - 22.9 cm x 22.9 cm x 3.8 cm
 - 1.4 kg
 - Limited lifetime warranty
 - 22.9 cm
 - 22.9 cm
 - 3.8 cm
 - 1.4 kg
- Localisation
Processor / Memory / Storage
- RAM
 - 256 GB
- Flash Memory
 - 128 MB
- Form Factor
 - External
- Connectivity Technology
 - Wireless
- Data Transfer Rate
 - 2.8 Gbps
- Line Coding Format
 - 64 QAM, 256 QAM, BPSK, QPSK, 16 QAM, OFDM
- Spread Spectrum Method
 - OFDM, DSSS
 - NTP, DHCP, Bonjour
- Remote Management Protocol
 - SNMP 3, HTTP, HTTPS
- Frequency Band
 - 2.4 GHz, 5 GHz
- Capacity
- Status Indicators
 - Status
 - Load balancing, VLAN support, Syslog support, IPv6 support, firmware upgradable, Spanning Tree Protocol (STP) support, Wi-Fi Multimedia (WMM) support, Access Control List (ACL) support, Quality of Service (QoS), reset button, 3T3R MIMO technology, rogue access point detection, DHCP client, Energy Efficient Ethernet, e-mail notification, 4T4R MIMO technology, security lock slot (cable lock sold separately), 802.1x authentication, VoIP support, Link Aggregation, Wireless Scheduler, Dynamic Frequency Selection (DFS)
- Encryption Algorithm
 - WPA, WPA2, WPA-Enterprise, WPA2-Enterprise
- Authentication Method
 - RADIUS, Radio Service Set ID (SSID)
 - IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11e, IEEE 802.11n, IEEE 802.3at, IEEE 802.3az, IEEE 802.11ac
Aerial
- Antenna
 - Internal
- Antenna Qty
 - 4
 - 1 x 2.5 GBase-T (PoE+) - RJ-45 , 1 x 1000Base-T - RJ-45
- Cables Included
 - 1 x network cable
 - ICES-003, FCC Part 15.247, RSS-210, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15.107, FCC Part 15.109, FCC Part 15.407, EMI, EN 300 328, EN 301 489-1, AS/NZS 4268.2003, EN 301 893, CAN/CSA-C22.2 No. 60950-1, EN 301 489-17
 - PoE+
- OS Provided
 - Linux
 - Limited warranty - lifetime
 - 0 °C
 - 40 °C
 - 10 - 85% (non-condensing)
