Cisco Small Business WAP371 Radio Access Point 802.11a/b
Quicklinx: B24DWS00 Mfr#: WAP371-E-K9
  • IEEE 802.11n
Deliver high-speed wireless connectivity and guest access more securely and reliably in your small business. The Cisco WAP371 wireless-AC/N dual radio access point with single point setup is a simple yet powerful, high-performance access point. It offers business-class features such as Gigabit Ethernet connectivity, a captive portal for customized guest access, and robust security.
  • Enhanced connectivity
    The Cisco Small Business WAP371 offers seamless wireless connectivity with dual-band support, allowing devices to operate on 2.4 GHz or 5 GHz bands for optimized performance. Its 950 Mbps data transfer rate ensures high-speed Internet access for all connected devices.
  • Robust security
    Equipped with WPA and WPA2 encryption algorithms, this wireless access point provides a secure network environment. Advanced features like Access Control List (ACL) support, Multiple SSID support, and rogue access point detection further enhance network security, safeguarding your data from unauthorized access.
  • Flexible installation options
    Designed for versatility, the WAP371 is ceiling-mountable and wall-mountable, offering flexible installation options to suit various environments. Its compact form factor allows it to be placed in optimal locations for better wireless coverage.
  • Comprehensive network management
    Support for SNMP 3, HTTP, and HTTPS protocols enables efficient remote management of the network. Features such as Quality of Service (QoS), VLAN support, and Spanning Tree Protocol (STP) support allow for detailed network control and prioritization of network traffic, ensuring smooth operation.
  • Future-proof networking
    With support for IPv6, the Cisco Small Business WAP371 is ready for the next generation of network standards, ensuring your investment is protected as technology evolves. Its firmware is upgradable, allowing for new features and security enhancements to be added over time.
Cisco Small Business WAP371 - radio access point - Wi-Fi 5
Radio access point
External
Europe
RAM
64 MB
Flash Memory
32 MB
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Power Over Ethernet (PoE) Supported
PoE+
23 cm x 23 cm x 4.3 cm
740 g
Radio access point
23 cm
23 cm
4.3 cm
740 g
Europe
Processor / Memory / Storage
RAM
64 MB
Flash Memory
32 MB
External
Wireless
Data Transfer Rate
950 Mbps
Spread Spectrum Method
OFDM
Network / Transport Protocol
DHCP, Bonjour
Remote Management Protocol
SNMP 3, HTTP, HTTPS
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Power, LAN, wireless
Auto-sensing per device, load balancing, VLAN support, Syslog support, E-mail alert, IPv6 support, DFS support, Wireless Distribution System (WDS) support, firmware upgradable, wall mountable, Spanning Tree Protocol (STP) support, Wi-Fi Multimedia (WMM) support, event log, Access Control List (ACL) support, Quality of Service (QoS), Multiple SSID support, wireless bridge mode, reset button, IPv4 support, 3T3R MIMO technology, rogue access point detection, DHCP client, ceiling mountable, security lock slot (cable lock sold separately)
Encryption Algorithm
WPA, WPA2
Authentication Method
RADIUS, Radio Service Set ID (SSID)
IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11e, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac
Aerial
Antenna
Internal
Gain Level
2 dBi
1 x 1000Base-T (PoE+) - RJ-45
1 x network cable
ICES-003, FCC Part 15.247, RSS-210, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15.107, FCC Part 15.109, AS/NZS 4268, FCC Part 15.407, EN 300 328, EN 301 893, CAN/CSA-C22.2 No. 60950-1
PoE+
OS Provided
Linux
Limited warranty - lifetime
10 - 85% (non-condensing)
B24D C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.67
B24D C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.82
