Cisco Small Business WAP150 - Radio access point - Wi-Fi - Dual Ba
Quicklinx: F37RWS00 Mfr#: WAP150-E-K9-UK
  • IEEE 802.11n
To stay productive, they need dependable, business-class access to network applications throughout the office. Cisco WAP150 Wireless-AC/N Dual Radio Access Points provide a simple, cost-effective way to extend more secure, high-performance mobile networking to your employees and guests, so they can stay connected anywhere in the office. This flexible solution lets you connect dozens of employees, and can scale to accommodate additional users and changing business needs.
The WAP150 access point uses concurrent dual-band radios for improved coverage on mobile devices. Gigabit Ethernet LAN interfaces with Power over Ethernet (PoE) support flexible installation and can reduce cabling and wiring costs. Intelligent quality-of-service (QoS) features let you prioritize bandwidth-sensitive traffic for voice over IP (VoIP) and video applications.
To provide highly secure guest access to visitors and other users, WAP150 access points support a captive portal with multiple authentication options and the ability to configure rights, roles, and bandwidth. A customized guest login page lets you present a welcome message and access details, and reinforces your brand with company logos.
The WAP150 Wireless-AC/N Dual Radio Access Point is easy to set up and use, with intuitive wizard-based configuration to get you up and running in minutes. An attractive design with flexible mounting options allows the access points to blend well into any small business environment.
To enhance reliability and safeguard sensitive business information, WAP150 access points support both Wi-Fi Protected Access (WPA) Personal and Enterprise, encoding all your wireless transmissions with powerful encryption. In addition, 802.1X RADIUS authentication helps keep unauthorized users out.
  • CONNECTIVITY
    Provides cost-effective 802.11ac Wave 1 connectivity with speeds up to 1.2 Gbps and concurrent dual-band radios for improved coverage on mobile devices
  • TECHNOLOGY
    Supports 2x2 multiple-input multiple-output (MIMO) technology with two spatial streams for maximum performance on both 2.4- and 5.0-GHz radios
  • POWER OVER ETHERNET
    Gigabit Ethernet LAN interface with PoE support
  • GUEST WIFI
    Provides secure guest access with multiple authentication options; supports social media login such as Google and Facebook
  • PROTECTION
    Cisco Umbrella integration protects wireless devices from malware and phishing
Cisco Small Business WAP150 - radio access point - Wi-Fi
Radio access point
External
United Kingdom
RAM
256 MB
Flash Memory
128 MB
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Power Over Ethernet (PoE) Supported
PoE
DC 12 V
13.5 cm x 13.5 cm x 3.8 cm
350 g
Radio access point
13.5 cm
13.5 cm
3.8 cm
350 g
United Kingdom
Processor / Memory / Storage
RAM
256 MB
Flash Memory
128 MB
External
Wireless
Data Transfer Rate
1.2 Gbps
Spread Spectrum Method
OFDM
Network / Transport Protocol
DHCP, Bonjour
Remote Management Protocol
SNMP 3, HTTP, HTTPS
Frequency Band
2.4 GHz, 5 GHz
Load balancing, VLAN support, Syslog support, IPv6 support, Wireless Distribution System (WDS) support, wall mountable, Spanning Tree Protocol (STP) support, WPA2 encryption, Wi-Fi Multimedia (WMM) support, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, Multiple SSID support, wireless bridge mode, IPv4 support, rogue access point detection, ceiling mountable, NTP time synchronisation, 802.1x authentication, VoIP support, WPA encryption, SSID to VLAN mapping
Encryption Algorithm
WPA, WPA2
Authentication Method
RADIUS
IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11e, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac
Aerial
Antenna
Internal
1 x 1000Base-T - RJ-45
1 x network cable
ICES-003, FCC Part 15.247, RSS-210, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15.107, FCC Part 15.109, FCC Part 15.407, EMI, EN 300 328, EN 60204-1, AS/NZS 4268.2003, EN 301 893, CAN/CSA-C22.2 No. 60950-1, EN 301 489-17
PoE
External power adapter
DC 12 V
9.5 watt
OS Provided
Linux
Limited warranty - lifetime
10 - 85% (non-condensing)
