Cisco Small Business SG350-10MPSwitch L3 Managed 8 x10/100/1000
Quicklinx: D4KDWS00 Mfr#: SG350-10MP-K9-UK
Type: Gigabit Ethernet
Ports: 10
Managed: Yes
POE: PoE+
£233.68 ex VAT
£280.41 inc VAT
The Cisco 350 Series, part of the Cisco Small Business line of network solutions, is a portfolio of affordable managed switches that provides a reliable foundation for your business network. These switches deliver the features you need to improve the availability of your critical business applications, protect your sensitive information, and optimize your network bandwidth to deliver information and applications more effectively. Easy to set up and use, the Cisco 350 Series provides the ideal combination of affordability and capabilities for small businesses and helps you create a more efficient, better-connected workforce.
  • ETHERNET PORT CONFIGURATION
    8-port 10/100/1000, 2 x 1G uplinks (SFP)
  • POWER OVER ETHERNET
    8 PoE ports with 128W total power budget, PoE, PoE+, PoE PD port
  • CONFIGURATION & CONTROL
    Easy-to-use on-box WebUI, CLI, SNMP, Cisco FindIT Network Manager, PnP, Auto Smartports, auto-discovery, zero-touch deployment
  • L2+/L3 FEATURES
    Static routing, QoS, Voice/Guest VLAN, MSTP, IGMP Snooping, Time-based Access Control Lists, 802.1x, Web-based Authentication, IPv6 First Hop Security, IP Source Guard
  • PEACE OF MIND
    Limited-lifetime warranty, next-business-day replacement, one-year technical support, and free software fixes for the term of the warranty
Cisco Small Business SG350-10MP - switch - 10 ports - Managed
Switch - 10 ports - L3 - Managed
Enclosure Type
1U
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE+) + 2 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
128 W
Performance
Switching capacity: 20 Gbps , Forwarding performance (64-byte packet size): 14.88 Mpps
Active VLANs: 4096
MAC Address Table Size
16K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
Static IPv4 routing, CIDR
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH, CLI
Layer 3 switching, Layer 2 switching, DHCP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, MLD snooping, 12MB packet buffer
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3az
27.9 cm x 17 cm x 4.45 cm
1.19 kg
United Kingdom
Enclosure Type
Desktop 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
128 W
Performance
Active VLANs: 4096
16K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+
RAM
512 MB
Flash Memory
256 MB
Status Indicators
Link/activity
8 x 1000Base-T RJ-45 PoE+ - 124 W , 2 x 1000Base-T RJ-45/SFP PoE - 60 W , 1 x console RJ-45 management , 1 x USB management
External power adapter
152.6 Watt
1 x console cable
Rack Mounting Kit
Included
MTBF
80,093 hours
UL 60950, FCC Part 15 A, CSA 22.2
United Kingdom
27.9 cm
17 cm
4.45 cm
1.19 kg
Limited warranty - replacement - lifetime - response time: next business day , Technical support - web support - 1 year , Technical support - phone consulting - 1 year
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
D4KD Cisco Gigabit Ethernet SX Mini-GBIC In Stock £101.90
Ports: 10
Managed: Yes
POE: PoE+
Brand: Cisco
