Cisco Small Business SG250-10P Switch Smart 8 x 10/100/1000
Quicklinx: CD6PWS00 Mfr#: SG250-10P-K9-UK
  • ETHERNET PORT CONFIGURATION
    8-port 10/100/1000, 2 x 1G combo SFP
  • POWER OVER ETHERNET
    8 PoE ports with 62W total power budget, PoE, PoE+, PoE PD/PSE port
  • CONFIGURATION & CONTROL
    Easy-to-use on-box WebUI, CLI offers basic+ capabilities, SNMP, Cisco FindIT Network Manager, PnP, auto-discovery, zero-touch deployment
  • L2+ FEATURES AND SECURITY
    Static routing, VLANs, QoS, Voice VLAN, MSTP, IGMP Snooping Access Control List (ACL), 802.1X, DoS prevention, SSH/SSL
  • PEACE OF MIND
    Limited-lifetime warranty, one-year technical support, and free software fixes for the term of the warranty
Cisco 250 Series SG250-10P - switch - 10 ports - smart
Switch - 10 ports - smart
Enclosure Type
1U
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE+) + 2 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
62 W
Performance
Switching capacity: 20 Gbps , Forwarding performance (64-byte packet size): 14.88 Mpps
Active VLANs: 256
MAC Address Table Size
8K entries
Jumbo Frame Support
9000 bytes
Routing Protocol
IGMP, static IPv4 routing
Remote Management Protocol
SNMP, RMON, HTTP, HTTPS, TFTP, SCP
DHCP support, BOOTP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, WRR queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, SNTP support, STP support, RSTP support, MSTP support, TFTP support, QoS, MLD snooping, reset button, LLDP support, 12MB packet buffer, Storm Control, SmartPort technology, Cisco Discovery Protocol
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3az
AC 100-240 V (50 - 60 Hz)
28 cm x 17 cm x 4.4 cm
1.2 kg
United Kingdom
Enclosure Type
Desktop 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
62 W
Performance
Active VLANs: 256
8K entries
Jumbo Frame Support
9000 bytes
Routing Protocol
Encryption Algorithm
MD5, SSL
Authentication Method
RADIUS
RAM
512 MB
Flash Memory
256 MB
Status Indicators
Link/activity
8 x 1000Base-T RJ-45 PoE+ - 62 W , 2 x 1000Base-T RJ-45/SFP PoE - 60 W , 1 x USB management
External power adapter
1 x power cable
MTBF
205,647 hours
UL 60950, CSA 22.2, FCC CFR47 Part 15 A
United Kingdom
28 cm
17 cm
4.4 cm
1.2 kg
Limited warranty - replacement - lifetime - response time: next business day , Technical support - web support - 1 year , Technical support - phone consulting - 1 year
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
