Cisco Small Business SG110D-08HP Switch
Quicklinx: BTD5WS00 Mfr#: SG110D-08HP-UK
Type: Gigabit Ethernet
Ports: 8
Managed: No
POE: PoE
£101.47 ex VAT
£121.76 inc VAT
Cisco 110 series unmanaged switches deliver basic network connectivity and reliability for small businesses that's easy on the budget and without all the complexity. These switches provide all of the features, expandability, and investment protection you expect from Cisco. Just plug it in, connect your computers and other business equipment, and get to work.
Cisco 110 series unmanaged switches, part of the Cisco Small Business networking solutions, are a line of unmanaged switches that provide wire-speed fast Ethernet and Gigabit Ethernet connectivity to connect your small business office. These switches are designed to suit any office space with basic network needs and to optimize power efficiency. They use less power and provide the robust, reliable connectivity your business demands, as well as support for advanced features. A business-class, affordable network solution, Cisco 110 series switches bring the proven reliability and investment protection of Cisco networking solutions to your small business.
  • ETHERNET PORT CONFIGURATION
    8-port 10/100/1000 Gigabit
  • POWER OVER ETHERNET
    4 PoE ports with 32W total power budget
  • PLUG AND PLAY
    Simple set up with no software to install or configuration needed
  • PEACE OF MIND
    Limited-lifetime warranty and one-year technical support
  • SUPPORTED AUTOMATIC FEATURES
    Quality of service (QoS), loop detection, and cable diagnostics
Cisco Small Business SG110D-08HP - switch - 8 ports - unmanaged
Switch - 8 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
4 x 10/100/1000 + 4 x 10/100/1000 (PoE)
Power Over Ethernet (PoE)
PoE
PoE Budget
32 W
Performance
Switching capacity: 16 Gbps , Forwarding performance (64-byte packet size): 11.9 Mpps
QoS hardware queues: 4
Jumbo Frame Support
9216 bytes
Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), Weighted Round Robin (WRR) queuing, store and forward, Quality of Service (QoS), Cable Diagnostics Function, fanless, Energy Efficient Ethernet, loop prevention, security lock slot (cable lock sold separately)
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3az
16 cm x 12.85 cm x 3 cm
550 g
United Kingdom
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
PoE
PoE Budget
32 W
Performance
Jumbo Frame Support
9216 bytes
RAM
128 MB
Flash Memory
128 MB
Status Indicators
System, link/activity
4 x 1000Base-T RJ-45 , 4 x 1000Base-T RJ-45 PoE
External power adapter
UL 60950, FCC CFR47 Part 15, FCC Part 15 A, CSA 22.2
United Kingdom
16 cm
12.85 cm
3 cm
550 g
Limited warranty - lifetime
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
BTD5 Cisco Gigabit Ethernet SX Mini-GBIC In Stock £101.51
BTD5 Cisco Gigabit Ethernet LX Mini-GBIC SFP Transceiver In Stock £131.49
Ports: 8
Managed: No
POE: PoE
Brand: Cisco
