Give your office network a boost of speed and performance at a low price that takes almost no time to set up. Easily build a highly reliable network to connect your computers, printers, copiers, and other office equipment. If your business is like most small companies, you do not have an IT staff to set up your network for you. Now you can have a high-performance, business-class office network that just works, right out of the box, with the Cisco 110 Series Unmanaged Switches. Users, workgroups, labs, departments, or growing offices can now deliver large amounts of multimedia, image, and video information across the network in almost no time.
Cisco 110 Series Unmanaged Switches deliver basic network connectivity and reliability for small businesses that is easy on the budget and without all the complexity. These switches provide all of the features, expandability, and investment protection you expect from Cisco, with no installation software and nothing to configure. Just plug it in, connect your computers and other business equipment, and get to work.
ETHERNET PORT CONFIGURATION
16-port 10/100/1000 Gigabit -
PLUG AND PLAY
Simple set up with no software to install or configuration needed -
BUILT TO LAST
Rugged metal housing, fanless -
PEACE OF MIND
Limited-lifetime warranty and one-year technical support -
SUPPORTED AUTOMATIC FEATURES
Quality of service (QoS), loop detection, and cable diagnostics
- Cisco Small Business SG110-16 - switch - 16 ports - unmanaged - rack-mountable
- Switch - 16 ports - unmanaged
- Enclosure Type
- Rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 16 x 10/100/1000
- Performance
- Switching capacity: 32 Gbps , Forwarding performance (64-byte packet size): 23.8 Mpps
- Capacity
- QoS hardware queues: 4
- Jumbo Frame Support
- 9216 bytes
- Auto-negotiation, auto-uplink (auto MDI/MDI-X), Weighted Round Robin (WRR) queuing, Quality of Service (QoS), Energy Efficient Ethernet, security lock slot (cable lock sold separately), cable test
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
- Power
- AC 120/230 V (50 - 60 Hz)
- 27.94 cm x 17 cm x 4.45 cm
- 2.13 kg
- Localisation
- United Kingdom
- Limited lifetime warranty
- Enclosure Type
- Rack-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 16 x 10/100/1000
- Performance
- Capacity
- 9216 bytes
- RAM
- 128 MB
- Flash Memory
- 128 MB
- Status Indicators
- System, link/activity
- 16 x 1000Base-T RJ-45
- Power Device
- Internal power supply
- Voltage Required
- UL 60950, FCC CFR47 Part 15, CSA 22.2
- Localisation
- United Kingdom
- 27.94 cm
- 17 cm
- 4.45 cm
- 2.13 kg
- Limited warranty - lifetime
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 5 - 90% (non-condensing)
Cisco Gigabit Ethernet SX Mini-GBIC | In Stock | £98.96 |
