Cisco Small Business RV325 Desktop Router
Quicklinx: 9J7VWS00 Mfr#: RV325-K9-G5
The Cisco RV325 dual gigabit WAN VPN router is no exception. Featuring intuitive user interfaces, it will have you up and running in mere minutes. The capable router provides reliable, highly secure connectivity for you and your employees and work so well that you won't even know the router is there.
  • Robust security
    Equipped with advanced encryption algorithms including 128-bit AES, 192-bit AES, 256-bit AES, DES, MD5, SHA-1, and Triple DES, the Cisco RV325 ensures your network's security is strong. Its comprehensive security features protect against various threats, making it a suitable choice for businesses prioritizing data protection.
  • High-capacity VPN support
    The RV325 supports up to 25 IPSec VPN tunnels, 10 SSL VPN tunnels, and 10 PPTP VPN tunnels, enabling secure and efficient connectivity for remote employees and multiple office sites. This capability allows for flexible, secure remote access, making it suitable for businesses with a distributed workforce.
  • Enhanced connectivity
    With 14 LAN ports and 2 WAN ports, the Cisco RV325 offers ample connectivity options for small to medium-sized businesses. The integrated 14-port switch facilitates the connection of multiple devices, while dual WAN ports support load balancing and failover, ensuring uninterrupted Internet connectivity.
  • Comprehensive network features
    Featuring DHCP server, DNS relay, IPv6 support, Quality of Service (QoS), and Stateful Packet Inspection (SPI), the RV325 provides a robust set of tools to manage and optimize your network. These features, along with support for various network protocols, make it a versatile router for any business environment.
  • Easy management and setup
    The RV325 supports SNMP 1, SNMP 2c, and SNMP 3 for flexible remote management, alongside HTTP and HTTPS for secure web-based management. Its user-friendly interface ensures easy setup and management, allowing businesses to focus on their operations rather than their network infrastructure.
Cisco Small Business RV325 - router - desktop
Router - 14-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
2
Performance
NAT throughput: 900 Mbps , VPN throughput (IPSec): 100 Mbps , VPN throughput (SSL): 20 Mbps
Virtual interfaces (VLANs): 17 , PPTP VPN tunnels: 10 , SSL VPN tunnels: 10 , VPN tunnels (site-to-site): 25 , IPSec VPN tunnels: 25 , Concurrent connections: 40000 , ACL rules: 50
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, DHCP, Bonjour, DDNS
Routing Protocol
RIP-1, RIP-2, static IP routing, RIPng
Remote Management Protocol
SNMP 1, SNMP 3, SNMP 2c, HTTP, HTTPS
DMZ port, NAT support, hardware encryption, VPN support, PAT support, load balancing, Syslog support, SPI, DoS attack prevention, content filtering, E-mail alert, IPv6 support, firmware upgradable, QoS, IPSec NAT-T, DHCP server, reset button, bandwidth control, DHCP relay, DNS relay, DHCP client
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q
24.3 cm x 17.7 cm x 4.5 cm
Taiwan, Thailand, Singapore, India, Europe
Enclosure Type
Desktop
Wired
Performance
Routing Protocol
Encryption Algorithm
DES, Triple DES, MD5, SHA-1, 128-bit AES, 192-bit AES, 256-bit AES
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, FCC Class B certified, UL, BSMI, cUL, CB, CCC, ANATEL, KC
Status Indicators
Port transmission speed, power, WAN, DMZ, link/activity, DMZ/Internet, diagnostic, USB, VPN
LAN: 14 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN / DMZ: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 2 x 4 pin USB Type A
External power adapter
1 x network cable
Software Included
Drivers & Utilities
24.3 cm
17.7 cm
4.5 cm
Limited warranty - lifetime
10 - 85% (non-condensing)
9J7V C2G 2m USB 2.0 A/B Cable - Black In Stock £4.16
