Cisco Small Business RV130 - Router - 4-port switch - GigE
Quicklinx: BW58WS00 Mfr#: RV130-K9-G5
The Cisco RV130 VPN Router is an affordable, easy-to-use device that combines high-performance network connectivity to multiple offices and remote employees with essential business-class features. These include Gigabit Ethernet, Quality of Service, and advanced security, the features you need to successfully build your small business network.
  • High-performance Gigabit Ethernet ports, enabling large file transfers and multiple users
    The Cisco RV130 features a built-in 4-port Gigabit Ethernet managed switch that lets you connect network devices and transfer files and data at high speed. Intelligent quality of service (QoS) features let you prioritize network traffic to keep critical network applications like voice and video running at their best.
  • IP Security (IPsec) site-to-site VPN helps enables secure connectivity for remote employees and multiple offices
    To help you connect remote users or additional offices, the Cisco RV130 offers enterprise-class encryption and authentication, including support for IPsec and Point-to-Point Tunneling Protocol (PPTP) VPN client connections and IPsec gateway-to-gateway VPN tunnels.
  • USB port for 3G/4G modem failover or alternative primary connectivity
    The RV130 also features a USB port for 3G/4G Broadband failover or for alternative uses can be used for primary connectivity.
  • Easy to set up and use with wizard-based configuration
    Easy to set up and use right out of the box, the router features a simple wizard-based configuration to get you up and running in minutes.
Cisco Small Business RV130 - router - desktop
Router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Performance
NAT throughput: 800 Mbps , VPN throughput (IPSec): 50 Mbps
Concurrent sessions: 12000 , IPSec VPN tunnels: 10 , VPN tunnels: 10
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, DHCP, Bonjour, DDNS
Routing Protocol
RIP-1, RIP-2, IGMP, static IP routing
Remote Management Protocol
SNMP 1, SNMP 3, SNMP 2c, HTTP, HTTPS
Switching, NAT support, VPN support, PAT support, SPI, content filtering, DiffServ support, IPv6 support, VPN passthrough, firmware upgradable, SNTP support, WMM support, QoS, DHCP server, DNS proxy, port forwarding, IPv4 support
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.1p, IEEE 802.1x, X.509, UPnP
DC 12 V 1 A
Indonesia, Vietnam, Hong Kong, Thailand, Malaysia, Singapore, India, Philippines, Korea, Russia, Europe
Enclosure Type
Desktop
Wired
Performance
Routing Protocol
Encryption Algorithm
Triple DES, MD5, AES, SHA-1, PEAP
Authentication Method
RADIUS
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.1p, IEEE 802.1x, X.509, UPnP, FCC Class B certified, IC
Status Indicators
Power, WAN, LAN
LAN: 4 x 1000Base-T - RJ-45 , WAN: 1 x 1000Base-T - RJ-45
External power adapter
DC 12 V
Electric Current Required
1 A
1 x network cable
Limited warranty - lifetime
10 - 85% (non-condensing)
BW58 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.67
BW58 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.82
