Cisco Small Business 200 Series Smart Switch SG200-26P - switch - 26 ports - Managed - desktop
Quicklinx: 7BMYWS00 Mfr#: SLM2024PT-UK
The key to succeeding in today's competitive business environment is investing resources wisely and getting the most value for your dollars. What if you could achieve business-class security and performance in your small business network without paying for advanced network features your network may not need? Now you can with Cisco 200 series smart switch. When you need to share network resources and connect computers, printers, and servers, but low cost is a top priority, Cisco 200 series switch provides the ideal solution.
  • Simplify setup and management
    Cisco 200 series switch is designed to be easy to configure, manage, and troubleshoot, allowing you to focus on your business priorities.
  • Protect your business investment
    Cisco 200 series switch offers the reliable performance, investment protection, and peace of mind you expect from a Cisco switch.
  • A powerful foundation for the basic business network
    Cisco 200 series smart switch helps you build a business-class network. It provides just the right security, management, and QoS features you need to make the most of your business applications and productivity tools, without the costs or complexity of a managed switch.
Cisco Small Business Smart SG200-26P - switch - 26 ports - Managed - rack-mountable
Switch - 26 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
12 x 10/100/1000 (PoE) + 12 x 10/100/1000 + 2 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE
Performance
Switching capacity: 38.69 Mpps , Forwarding performance (64-byte packet size): 52 Gbps
MAC Address Table Size
8000 entries
Jumbo Frame Support
Remote Management Protocol
RMON, HTTP, TFTP
Layer 2 switching, DHCP support, PoE, BOOTP support, VLAN support, IGMP snooping, Syslog support, port mirroring, DiffServ support, WRR queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, SNTP support, STP support, TFTP support, QoS, Jumbo Frames support, MLD snooping
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x
44 cm x 25.7 cm x 4.4 cm
3.8 kg
United Kingdom
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE
Performance
8000 entries
Jumbo Frame Support
RMON, HTTP, TFTP
Encryption Algorithm
MD5
Authentication Method
RADIUS
RAM
128 MB
Flash Memory
16 MB
Status Indicators
Port transmission speed, system, PoE, link/activity
12 x 1000Base-T RJ-45 , 12 x 1000Base-T RJ-45 PoE , 2 x SFP (mini-GBIC)
Internal power supply
Mounting Kit
Included
MTBF
218,842 hours
UL 60950, FCC Part 15 A, CSA 22.2
United Kingdom
44 cm
25.7 cm
4.4 cm
3.8 kg
Limited warranty - lifetime , Technical support - web support - 1 year , Technical support - phone consulting - 1 year
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
