Cisco Small Business - PoE injector - 30 Watt
Quicklinx: B90HWS00 Mfr#: SB-PWR-INJ2-UK
£60.30 ex VAT
£72.36 inc VAT
  • CONNECTIVITY
    Delivers PoE connectivity to 802.3at compliant endpoint devices and backward compatible with 802.3af
  • WORKS WITH
    Compatible with Cisco Small Business Wireless Access Points
  • DESIGN
    Compact design fits easily in WLAN Access Point installations
  • CONNECTIVITY
    Gigabit LAN ports provide high-speed connectivity to the LAN and endpoint device
  • POWER OVER ETHERNET
    Adds PoE capability to a non-PoE Ethernet switch or router
PoE injector - external
200 g
United Kingdom
Input Voltage
AC 100-240 V
Output Voltage
55 V
Power Capacity
30 Watt
5.3 cm x 14 cm x 3.25 cm
Small Business WAP351
United Kingdom
Input Voltage
AC 100-240 V
Frequency Required
50/60 Hz
Output Voltage
55 V
Max Electric Current
0.8 A
Power Capacity
30 Watt
1 x LAN - RJ-45
MTBF
100,000 hours
FCC Class B certified, UL, cUL, RoHS
10 - 85% (non-condensing)
5.3 cm
14 cm
3.25 cm
200 g
Cisco Small Business WAP351
