The Cisco 350 Series, part of the Cisco Small Business line of network solutions, is a portfolio of affordable managed switches that provides a reliable foundation for your business network. These switches deliver the features you need to improve the availability of your critical business applications, protect your sensitive information, and optimize your network bandwidth to deliver information and applications more effectively. Easy to set up and use, the Cisco 350 Series provides the ideal combination of affordability and capabilities for small businesses and helps you create a more efficient, better-connected workforce.
ETHERNET PORT CONFIGURATION
8-port 10/100/1000, 2 x 1G uplinks (SFP) -
POWER OVER ETHERNET
8 PoE ports with 62W total power budget, PoE, PoE+, PoE PD port -
CONFIGURATION & CONTROL
Easy-to-use on-box WebUI, CLI, SNMP, Cisco FindIT Network Manager, PnP, Auto Smartports, auto-discovery, zero-touch deployment -
L2+/L3 FEATURES
Static routing, QoS, Voice/Guest VLAN, MSTP, IGMP Snooping, Time-based Access Control Lists, 802.1x, Web-based Authentication, IPv6 First Hop Security, IP Source Guard -
PEACE OF MIND
Limited-lifetime warranty, next-business-day replacement, one-year technical support, and free software fixes for the term of the warranty
- Cisco Small Business SG350-10P - switch - 10 ports - Managed
- Switch - 10 ports - L3 - Managed
- Enclosure Type
- 1U
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000 (PoE+) + 2 x combo Gigabit SFP
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 62 W
- Performance
- Switching capacity: 20 Gbps , Forwarding performance (64-byte packet size): 14.88 Mpps
- Capacity
- Active VLANs: 4096
- MAC Address Table Size
- 16K entries
- Jumbo Frame Support
- 9216 bytes
- Routing Protocol
- Static IPv4 routing, CIDR
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH, CLI
- Layer 3 switching, Layer 2 switching, DHCP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, MLD snooping, 12MB packet buffer
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3az
- Power
- AC 120/230 V (50/60 Hz)
- 27.9 cm x 17 cm x 4.45 cm
- 1.19 kg
- Localisation
- United Kingdom
- Limited lifetime warranty
- Enclosure Type
- Desktop 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 62 W
- Performance
- Capacity
- 16K entries
- 9216 bytes
- Routing Protocol
- Encryption Algorithm
- SSL
- Authentication Method
- Secure Shell (SSH), RADIUS, TACACS+
- RAM
- 512 MB
- Flash Memory
- 256 MB
- Status Indicators
- Link/activity
- 8 x 1000Base-T RJ-45 PoE+ - 62 W , 2 x 1000Base-T RJ-45/SFP PoE - 60 W , 1 x console RJ-45 management , 1 x USB management
- Power Device
- External power adapter
- Voltage Required
- 84.7 Watt
- Cables Included
- 1 x console cable
- Rack Mounting Kit
- Included
- MTBF
- 205,647 hours
- UL 60950, FCC Part 15 A, CSA 22.2
- Localisation
- United Kingdom
- 27.9 cm
- 17 cm
- 4.45 cm
- 1.19 kg
- Limited warranty - replacement - lifetime - response time: next business day , Technical support - web support - 1 year , Technical support - phone consulting - 1 year
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
Cisco Gigabit Ethernet SX Mini-GBIC | In Stock | £98.70 |
