The Cisco 250 series is the next generation of affordable smart switches that combine powerful network performance and reliability with the essential network management features you need for a solid business network. These expandable Fast Ethernet or Gigabit Ethernet switches provide basic management, security, and quality-of-service (QoS) features beyond those of an unmanaged or consumer-grade switch, at a lower cost than managed switches. And with an easy-to-use web user interface, Auto Smartports, and flexible Power over Ethernet (PoE) Plus capability, you can deploy and configure a complete business network in minutes.
ETHERNET PORT CONFIGURATION
24-port 10/100/1000, 2 x 1G combo SFP -
POWER OVER ETHERNET
24 PoE ports with 195W total power budget, PoE, PoE+ -
CONFIGURATION & CONTROL
Easy-to-use GUI interface and CLI offers basic+ capabilities, SNMP, Cisco FindIT Network Manager, PnP -
L2+ FEATURES AND SECURITY
Static routing, VLANs, QoS, Voice VLAN, MSTP, IGMP Snooping Access Control List (ACL), 802.1X, DoS prevention, SSH/SSL -
PEACE OF MIND
Limited-lifetime warranty, one-year technical support, and free software fixes for the term of the warranty
- Cisco 250 Series SG250-26P - switch - 26 ports - smart - rack-mountable
- Switch - 26 ports - smart
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 24 x 10/100/1000 (PoE+) + 2 x combo Gigabit SFP
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 195 W
- Performance
- Switching capacity: 52 Gbps , Forwarding performance (64-byte packet size): 38.69 Mpps
- Capacity
- MSTP instances: 8 , Active VLANs: 256 , QoS hardware queues: 4
- MAC Address Table Size
- 8K entries
- Jumbo Frame Support
- 9000 bytes
- Routing Protocol
- IGMP, static IPv4 routing
- Remote Management Protocol
- SNMP, RMON, HTTP, HTTPS, TFTP, SCP
- DHCP support, BOOTP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, WRR queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, SNTP support, STP support, RSTP support, MSTP support, TFTP support, QoS, MLD snooping, reset button, LLDP support, 12MB packet buffer, Storm Control, SmartPort technology, Cisco Discovery Protocol
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3az
- Power
- AC 100-240 V (50 - 60 Hz)
- 44 cm x 25.7 cm x 4.4 cm
- 3.81 kg
- Localisation
- United Kingdom
- Limited lifetime warranty
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 195 W
- Performance
- Capacity
- 8K entries
- 9000 bytes
- Routing Protocol
- Encryption Algorithm
- MD5, SSL
- Authentication Method
- RADIUS
- Processor
- X ARM: 800 MHz
- RAM
- 512 MB
- Flash Memory
- 256 MB
- Status Indicators
- Link/activity
- 24 x 1000Base-T RJ-45 PoE+ - 195 W , 2 x 1000Base-T RJ-45/SFP , 1 x USB management
- Power Device
- Internal power supply
- Voltage Required
- Cables Included
- 1 x power cable
- MTBF
- 430,341 hours
- UL 60950, CSA 22.2, FCC CFR47 Part 15 A
- Localisation
- United Kingdom
- 44 cm
- 25.7 cm
- 4.4 cm
- 3.81 kg
- Limited warranty - replacement - lifetime - response time: next business day , Technical support - web support - 1 year , Technical support - phone consulting - 1 year
- 0 °C
- 50 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
