Cisco Small Business 220 series smart plus switches bridge the gap between managed and smart switches to offer customers the best of both worlds. Combining powerful performance with reliability, they provide the higher levels of security, management, and scalability you expect from managed switches, affordably priced like smart switches.
The Cisco 220 series switches provide the management capabilities, enhanced security, and quality of service features needed to support business-class data, voice, security, and wireless services.
ETHERNET PORT CONFIGURATION
48-port 10/100/1000, 2 x 1G combo SFP -
CONFIGURATION & CONTROL
Easy-to-use GUI interface and CLI offers basic+ capabilities, SNMP -
KEY FEATURES
VLANs, QoS, Link Aggregation, Port Mirroring, Spanning Tree and IGMP Snooping -
SECURITY FEATURES
Access Control List (ACL), 802.1X / RADIUS, DoS prevention -
PEACE OF MIND
Limited-lifetime warranty, one-year technical support, and free software fixes for the term of the warranty
- Cisco 220 Series SG220-50 - switch - 50 ports - Managed - rack-mountable
- Switch - 50 ports - Managed
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 48 x 10/100/1000 + 2 x combo Gigabit SFP
- Performance
- Forwarding performance (64-byte packet size): 74.4 mpps , Switching capacity: 100 Gbps
- MAC Address Table Size
- 8192 entries
- Jumbo Frame Support
- 9216 bytes
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, CLI
- Flow control, Layer 2 switching, BOOTP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, MAC address filtering, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping, reset button, LLDP support, DHCP relay, DHCP client, Energy Efficient Ethernet, 12MB packet buffer, Generic Attribute Registration Protocol (GARP), Generic VLAN Registration Protocol (GVRP), Type of Service (ToS)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3az
- Power
- AC 120/230 V (50/60 Hz)
- 44 cm x 20.1 cm x 4.4 cm
- 3.3 kg
- Localisation
- United Kingdom
- Limited lifetime warranty
- Enclosure Type
- Desktop, rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- Performance
- 8192 entries
- 9216 bytes
- Authentication Method
- RADIUS, TACACS+
- RAM
- 128 MB
- Flash Memory
- 32 MB
- Status Indicators
- Port transmission speed, system, link/activity
- 50 x 1000Base-T RJ-45 , 2 x SFP
- Power Device
- Internal power supply
- Voltage Required
- Cables Included
- 1 x console cable
- Rack Mounting Kit
- Included
- MTBF
- 382,742 hours
- C-Tick, UL 60950, FCC CFR47 Part 15, CSA 22.2
- Localisation
- United Kingdom
- 44 cm
- 20.1 cm
- 4.4 cm
- 3.3 kg
- Limited warranty - replacement - lifetime , Technical support - web support - 1 year , Technical support - phone consulting - 1 year , Limited warranty - power supply and fans - 1 year , Limited warranty - software - 90 days
- 0 °C
- 50 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £2.27 |
C2G 2m Cat6a Shielded Patch - Blue | In Stock | £6.80 |
