Cisco SG220-26 26-Port Gigabit Smart Plus Switch
Quicklinx: C9YWWS00 Mfr#: SG220-26-K9-UK
Type: Gigabit Ethernet
Ports: 26
Managed: Yes
£189.36 ex VAT
£227.23 inc VAT
Cisco Small Business 220 series smart plus switches bridge the gap between managed and smart switches to offer customers the best of both worlds. Combining powerful performance with reliability, they provide the higher levels of security, management, and scalability you expect from managed switches, affordably priced like smart switches.
The Cisco 220 series switches provide the management capabilities, enhanced security, and quality of service features needed to support business-class data, voice, security, and wireless services.
  • ETHERNET PORT CONFIGURATION
    24-port 10/100/1000, 2 x 1G combo SFP
  • CONFIGURATION & CONTROL
    Easy-to-use GUI interface and CLI offers basic+ capabilities, SNMP
  • KEY FEATURES
    VLANs, QoS, Link Aggregation, Port Mirroring, Spanning Tree and IGMP Snooping
  • SECURITY FEATURES
    Access Control List (ACL), 802.1X / RADIUS, DoS prevention
  • PEACE OF MIND
    Limited-lifetime warranty, one-year technical support, and free software fixes for the term of the warranty
Cisco 220 Series SG220-26 - switch - 26 ports - Managed - rack-mountable
Switch - 26 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 2 x combo Gigabit SFP
Performance
Forwarding performance (64-byte packet size): 38.69 Mpps ¦ Switching capacity: 52 Gbps
MAC Address Table Size
8192 entries
Jumbo Frame Support
9216 bytes
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, CLI
Flow control, Layer 2 switching, BOOTP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, MAC address filtering, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping, reset button, fanless, LLDP support, DHCP relay, DHCP client, Energy Efficient Ethernet, Generic Attribute Registration Protocol (GARP), Generic VLAN Registration Protocol (GVRP), Type of Service (ToS), 4.1MB packet buffer
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3az
44 cm x 20.1 cm x 4.4 cm
2.81 kg
United Kingdom
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
8192 entries
Jumbo Frame Support
9216 bytes
Authentication Method
RADIUS, TACACS+
RAM
128 MB
Flash Memory
32 MB
Status Indicators
Port transmission speed, system, link/activity
26 x 1000Base-T RJ-45 , 2 x SFP
Internal power supply
1 x console cable
Rack Mounting Kit
Included
MTBF
342,867 hours
C-Tick, UL 60950, FCC CFR47 Part 15, CSA 22.2
United Kingdom
44 cm
20.1 cm
4.4 cm
2.81 kg
Limited warranty - replacement - lifetime ¦ Technical support - web support - 1 year ¦ Technical support - phone consulting - 1 year ¦ Limited warranty - power supply and fans - 1 year ¦ Limited warranty - software - 90 days
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
C9YW C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.67
C9YW C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.82
Ports: 26
Managed: Yes
Brand: Cisco
