Build a fast, reliable network that connects your computers, printers, copiers, and other business machines without a lot of complexity. Cisco 100 Series unmanaged switches offer high-performance, business-class switching capabilities that are affordable and ready to use.
ETHERNET PORT CONFIGURATION
8-port 10/100/1000 Gigabit -
PLUG AND PLAY
Simple set up with no software to install or configuration needed -
BUILT TO LAST
Rugged metal housing, fanless -
PEACE OF MIND
Limited-lifetime warranty and one-year technical support -
SUPPORTED AUTOMATIC FEATURES
Quality of service (QoS), loop detection, and cable diagnostics
- Cisco Small Business SG110D-08 - switch - 8 ports - unmanaged
- Switch - 8 ports - unmanaged
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000
- Layer 2 switching, Quality of Service (QoS), Cable Diagnostics Function, Energy Efficient Ethernet, Class of Service (CoS)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3az
- Power
- AC 120/230 V
- 16 cm x 10.35 cm x 3 cm
- 426.5 g
- Localisation
- United Kingdom
- Limited lifetime warranty
- Enclosure Type
- Desktop, wall-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000
- Status Indicators
- Status
- 8 x 1000Base-T RJ-45
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Localisation
- United Kingdom
- 16 cm
- 10.35 cm
- 3 cm
- 426.5 g
- Limited warranty - replacement - lifetime
- 0 °C
- 50 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
Cisco Gigabit Ethernet SX Mini-GBIC | In Stock | £97.48 |
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £8.56 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.71 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £14.87 |
Cisco Gigabit Ethernet LX Mini-GBIC SFP Transceiver | In Stock | £126.25 |
