Cisco 200 series switch is a series of affordable smart switch that combine powerful network performance and reliability with the essential network management features you need for a solid business network. This expandable fast Gigabit Ethernet switch provides basic management, security, and quality-of-service (QoS) features beyond those of an unmanaged or consumer-grade switch, at a lower cost than managed switch. And with an easy-to-use web user interface, Cisco discovery protocol and Cisco Smartports you can deploy and configure a rock-solid business network in minutes.
Easy configuration and management
Cisco 200 series switch is designed to be easy to deploy and use by small businesses or the partners that serve them. Simple-to-use web-based interfaces reduce the time it takes to deploy, manage, and troubleshoot your network. -
Performance and reliability
Cisco 200 series switch has been tested to deliver the high availability and performance you would expect from a Cisco switch and help you prevent costly downtime. The switch speed file transfer times, improve slow and sluggish networks, keep your vital business applications available, and help your employees respond more quickly to customers and each other. With a network based on Cisco 200 series switch, you can address all of your business communication and connectivity needs and reduce the total cost of ownership of your technology infrastructure. -
Network security
Cisco 200 series switch provides basic security and network management features you need to maintain a level of security for your business, keep unauthorized users off the network, and protect your business data. The switch provides integrated network security to reduce the risk of a security breach, with IEEE 802.1X port security to control access to your network. -
IP telephony support
Cisco 200 series switch include QoS features to prioritize delay-sensitive services such as voice and video, simplify unified communications deployments, and help ensure consistent network performance for all services. For example, Auto Voice VLAN capabilities let you plug any IP phone into your IP telephony network and receive an immediate dial tone. The switch automatically configures the device with the right VLAN and QoS parameters to prioritize voice traffic. -
IPv6 support
As the IP network addressing scheme evolves to accommodate more devices, you can make sure that your network is ready. Cisco 200 series switch provides native support for IPv6 alongside traditional IPv4. That means you can take full advantage of IPv6-enabled operating systems and applications in the future, without having to upgrade your network equipment. -
An energy-efficient solution
Cisco 200 series switch is designed to be energy efficient and eco-friendly without compromising performance. It helps conserve energy by optimizing power use, which helps protect the environment and lowers your energy costs.
- Cisco Small Business Smart SG200-08 - switch - 8 ports - Managed
- Switch - 8 ports - Managed
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000
- Performance
- Switching capacity: 13.6 Gbps , Forwarding performance (64-byte packet size): 11.9 Mpps
- MAC Address Table Size
- 8000 entries
- Jumbo Frame Support
- Remote Management Protocol
- RMON, HTTP, TFTP
- Layer 2 switching, DHCP support, BOOTP support, VLAN support, IGMP snooping, Syslog support, port mirroring, DiffServ support, WRR queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, SNTP support, STP support, TFTP support, QoS, Jumbo Frames support, MLD snooping, fanless
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x
- Power
- AC 120/230 V (50/60 Hz)
- 11.3 cm x 13 cm x 2.7 cm
- 0.75 kg
- Localisation
- United Kingdom
- Limited lifetime warranty
- Enclosure Type
- Desktop, wall-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000
- Performance
- 8000 entries
- RMON, HTTP, TFTP
- Encryption Algorithm
- MD5
- Authentication Method
- RADIUS
- RAM
- 32 MB
- Flash Memory
- 8 MB
- Status Indicators
- Port transmission speed, system, link/activity
- 8 x 1000Base-T RJ-45
- Power Device
- Internal power supply
- Voltage Required
- Mounting Kit
- Included
- MTBF
- 71,834 hours
- UL 60950, FCC Part 15 A, CSA 22.2
- Localisation
- United Kingdom
- 11.3 cm
- 13 cm
- 2.7 cm
- 0.75 kg
- Limited warranty - lifetime , Technical support - web support - 1 year , Technical support - phone consulting - 1 year
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.67 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £9.82 |
